JDM v35 dual-din HVAC panel pinout
Does anyone have access to JDM Nissan service manuals or a ~2006 JDM v35 350GT/G35 coupe double din HVAC panel? I need a pinout or pictures of both sides the wires going into the plug, I already converted it to work with usdm dual climate, but the seller cut the plug off, and the colors are different from usdm. Spent 6 hours now searching and I can't find anything, please help!
https://cimg9.ibsrv.net/gimg/g35driv...222b4d1249.jpg |
PM me some pics of the back of the PCB. I'll try to help you out since I'm cutting a 05' board down and can hopefully get you some wiring info.
Originally Posted by scumbagsleeper
(Post 7159477)
here are the pics of both board's wires also for reference: https://cimg9.ibsrv.net/gimg/g35driv...df3eef14ae.jpg jdm https://cimg4.ibsrv.net/gimg/g35driv...dceb351129.jpg jdm https://cimg0.ibsrv.net/gimg/g35driv...cfe17d0a78.jpg usdm https://cimg1.ibsrv.net/gimg/g35driv...70e3234246.jpg usdm I soldered the button for dual climate onto the board, as well as the led backlight for the button and switched the plastic button panel from the old one, but the dual climate button still doesn't work at all, or even light up. not sure if i was supposed to do more, i heard about swapping a chip from the old board as well, and i have the hot air-soldering equipment to do it, but i haven't been able to find any good documentation on this. |
Cool, thanks for the pics. I haven't seen a JDM 05-06 board yet. It's interesting that they didn't use the same CPU for the HVAC control... Not sure why your dual isn't working, I've seen the older generation boards add a switch and LED and work but not the newer ones yet.
