Brake Ducts
I did take pictures of where the plumbing would run about a year back. A little cutting of the plastic on the inside of the wheel well will get cut. It looked like you could do it without cutting but you'd have to squish the tube somewhat.
I'm going to see about starting some ducting with those universals from above after my vacation. I put on some new smaller rims and it must have really cut down on the air flow because I actually boiled some old Motul 660 fuild in my brake lines. A quick bleed fixed it right up but extra air should solve the problem forever.
Thats got a 3" duct. Which is about all I'll be able to fit in there.
#30
Undoubtly I'll still have some air blowing directly onto the rotor. If this starts to cause uneven wear I'll probably end up a attaching small trianglar pipe do direct the air better.
One way to find out!
