05 6MT Coupe Tein 350Z H-tech install pics Before/After
Originally Posted by dream_G35
i'm running the same setup but the only question i still have is why does the rear not get lower than stock, actually it seems slightly higher
i'm gonna be looking at whats going on while i change my brakes next weekend.....anyone else with these springs feel the same way?
p.s. by all means whoever is thinking about getting this please do so, youwillbe happy it is a good drop just i am picky about little things.
Rides better than stock IMO.
Originally Posted by patman530
Ride is almost exactly the same as stock. I honestly cannot tell the difference. I will align the car in a few days so I will let you know how close to OEM specs I can get it. From what I've read on this forum, camber kit should not be needed with these springs. What kind of pics are you interested in seeing?
on
im looking to getting the same springs. thanks for the pics. they look exactly like what i want. congrats!
did you consider the S-tech? I know the spring rates for the H-tech is A LOT softer then the '05+ G35 w/ sport suspension. the H-tech for Z is 375 spring rate while OEM is 427. thats why i want S-tech which is 402 but 386 up front, oem is 314.
just worried the S-tech Z will lower the G too much. whats others opinions on this?
Finally got around to getting my alignment done. The results are similar to what others on the board have been getting, with rear being close to spec, but front a bit off (not adjustable). I'm not too concerned though, since my rear tires are already wearing at twice the rate of my front tires anyway.
