Fork out $1k for camber kit?
Old Jan 18, 2007 | 02:23 AM
cloud's Avatar
My camber settings is as below
-1.3 LF -1.6 RF
-1.6 LR -1.6 RR
Should I pay that much for a camber kit? or do I not need it at all. They are barely within spec.
Old Jan 18, 2007 | 02:24 AM
redlude97's Avatar
what are you lowered on? seems like you are good as far as camber, whats your toe at, its more important
Old Jan 18, 2007 | 03:02 AM
cloud's Avatar
the toes are within nominal specs
People have told me that the tires will wear badly? because it is at the limits of the factory specs range?
Toe is 0.05 for both fronts and 0.11 for both rears
Old Jan 18, 2007 | 03:10 AM
98intrigue's Avatar
That's nothing! My front camber is -1.8 and -1.9. My rear camber is -2.8 and -2.9...all on 350Z h-tech springs
Old Jan 18, 2007 | 06:18 AM
eat rice z33's Avatar
your camber is not bad at all. i would say a nice setting for added traction as long as your toe is right. I run -2 on my honda! hehe and its not bad at all. I plan on running around -1.5 onmy Z with my coilovers.
Old Jan 18, 2007 | 09:34 AM
GreenGoblin's Avatar
The goblin resurrection
that is fine I wouldnt get a camber kit
Old Jan 18, 2007 | 11:42 AM
cloud's Avatar
If i get rear camber kit, does it mean I lose the rear toe adjustability?
do I have to get a toe adjustment kit as well ?
or can I get an aftermarket camber kit and keep the OEM traction(toe) arms?
edit: lowered on HKS RS coilovers
I got brand new michelin Ps2s don't wanna ruin them.
Old Jan 18, 2007 | 12:57 PM
cloud's Avatar
bump, got a sweet deal for 350evo arms at $600. should I jump on it?
Old Jan 18, 2007 | 02:32 PM
Aznteazer's Avatar
600?? that's a steal. i paid 875 shipped from 350evo.
quality is so much better.
Old Jan 18, 2007 | 02:57 PM
SFLG35's Avatar
FGC President
hell yes
if your not goin to take it pm me the guy and i buy them for 600
Old Jan 19, 2007 | 02:09 AM
For handling enhancemetn your gonna need to run some negative camber. If you dont care at all about performance and simply want to extend the tier life by the little amount. Get from upper control arms. even 400 dollar cusco ones are great! and for the rear get camber arms. Even toe if you want. Most importantly get it aligned by a performance shop. And get it corner balanced. The alignment and balancing should cost around 250 total MAX.
Old Jan 19, 2007 | 10:18 PM
Andy@Performance's Avatar
I agree. Straightening your camber will affect the way the car handles and it is not good. The car from the factory comes with negative camber to enhance the way the car handles. If you straighten out your camber, you are sacrificing handling for even tire wear, traction, and slightly better braking. Front upper control arms like Cusco adjust camber by going negative, you wouldnt be able to straighten out your camber with this arm. It can only go negative to improve the handling of the car.
I personally love having negative camber. With the car corner balanced, it handles much better on the track. Plus you have more options to go with a lower offset wheel.
Old Jan 20, 2007 | 05:34 PM
Rphillips6487's Avatar
hey guys,
I was about to purchasr the tein basic coilovers with spc front and rear cambers but now ive been noticing the spc arnt so hot from others..
im still going to purchase the tein basic coilovers but now im looking at possibly the 350evo front cambers and no idea on the rear cambers atm..
im planning to lower my car 1.5"
im also going to purchase sway bars, not sure which ones iether..
just when I think I have what I need/want... lol
---can someone help me get a good setup here..
Old Jan 22, 2007 | 02:47 AM
cloud's Avatar
googled it but can someone explain corner balance better? who does it? the alignment shop?
Old Jan 22, 2007 | 10:57 AM
Gsedan35's Avatar
Here's the who part in your area.
http://www.my350z.com/forum/showthre...ghlight=fresno
The basic idea is make the amount of weight sitting on each corner of the suspension is made as even as possible. This is done by raising or lowering each corner of the car and using scales on each corner that read the amount of weight at each wheel. On a suspension that doesn't have full lenght adjustable dampner's, you are playing with spring preload level's when you change ride height of course.
I recommend going to my350z and running a search on corner weighting, should bring up some description's that may help more.
uoftguy
V36 Brakes, Suspension, Wheels & Tires
34
Aug 26, 2019 07:15 PM
Z1Motorsports
Engine-Vendor
202
May 25, 2017 03:58 PM
Brew_haha
Jul 9, 2014 06:00 AM
bkchang79
Apr 13, 2004 11:09 AM
