G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Brakes & Suspension (https://g35driver.com/forums/brakes-suspension-164/)
-   -   Tein basic's (https://g35driver.com/forums/brakes-suspension/139966-tein-basics.html)
ryman546 Feb 14, 2007 09:46 AM
Tein basic's
So ive decided to go with the basic's anyone got suggestions on where to find the best price :-P
ryman546 Feb 14, 2007 10:17 AM
Also will i need anything else to drop my car over 1" besides the coilovers?
Cost a G Feb 14, 2007 10:24 AM
Check some of the vendors..sometimes they have some killer deals. As for as your drop..you may need some camber kits..just do a search.
Calvin Feb 14, 2007 11:07 AM
youll most likely want f/r camber kits.
chances are, youre not going to slam it and you can probably live with some neg camber in the front. but definitely invest in the spc rear camber kit and toe bolts to save your rear tires.
ryman546 Feb 14, 2007 11:26 AM
meh. alot of $
FL-G35 Feb 14, 2007 11:31 AM
What aHero is saying that you would want to get the camber kit so you do not burn your tires out every 5 months because of your negative camber by dropping your car with the basics. I have the Basics and dropped my car but have yet to get the camber kit. Believe me when I say if you drive it daily and far you would want them because your tires will wear on the inside and your tread life is reduced drastically
Calvin Feb 14, 2007 02:41 PM
my friend is on basics with no camber kits. now, given that he is slammed (not all the way), hes got -3 all around. he plans on slamming it more..but he changes tires as often as i change boxers...:p
camber kit will save you money in the long run..lots of it..
G-Ride Canada Feb 14, 2007 03:18 PM
Just wondering...wouldn't front tires wear out fast if you dont have a front camber kit? ya it is expensive
Calvin Feb 14, 2007 03:34 PM
all tires will "wear out fast" without a camber kit if youre dropped..
O HELLA JDM Feb 14, 2007 03:56 PM
yo cal on the topic of tire wear.... droppin on h-techs... and putting the alignment to factory specs...how long do you think tires would last...
12 to 20k maybe??
redlude97 Feb 14, 2007 03:56 PM
-3 all around? whats his toe at? He'd probably save money getting camber kits
Calvin Feb 14, 2007 05:11 PM
he likes the look of neg camber (i like it too, actually. but unlike my friend, i can't afford tires every other week, lol)
Calvin Feb 14, 2007 05:12 PM
12 to 20k maybe??
depends what tires
and 12-20k is a huge range..
© 2026 MH Sub I, LLC dba Internet Brands
