Oem 19's & Spacers?
Just curious to whether anyone is running anything more then a 15mm Spacer in the Front and 20mm Spacer for the rear? I know one member is running this setup with OEM 19's. I was wondering if I could even run 25 for the front and 30 for the rear? Would my tires be past the fender? Just wondering if anyone was running this setup or something similiar?
I would go 20 front and 25 rear and roll the rear fender.
and then Post up the pictures.. thats the setup i will be doing soon. |
15 and 20 are ideal i think unless you want to deal with fender rolling. 25 and 30 is pushing it too far since i read that some people are having trouble with rubbing the front when turned all the way or going through dips when they're only running 15 in the front
30 will definetly fit in the rear with a roll, 25 will likely fit but rub slightly on sharp driveway turns at full lock
THANX for the info. I think I'll try the 20 and 25
| All times are GMT -4. The time now is 12:39 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
