G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Brakes & Suspension (https://g35driver.com/forums/brakes-suspension-164/)
-   -   im about to put 20's on my car...... (https://g35driver.com/forums/brakes-suspension/188840-im-about-put-20s-my-car.html)
deanfootlong Nov 20, 2007 10:31 PM
but i have stock suspension right now.
im looking to put 20's on my car. 245-35-20 front. 275-30-20 rear to be exact. however, i have stock suspension right now. I just want to drop the car a wee bit so it doesnt look retarded having 20's and a big gap between the fender and tires. what kind of suspension should i go for? im thinking about tein H techs so i just drop it a little bit. but i dont want to have to buy expensive camber kits to correct the camber. would tein H techs be ok without any camber adjustment and 20's? or would it still have too huge of a gap?
suggestions on wheel fitment suspension set up?
snavematt Nov 20, 2007 10:50 PM
dont know what H techs would do with the camber, Im sure it will still throw it off, my S techs moved me 2 degrees off with the same tire sizes
escobar929 Nov 20, 2007 10:55 PM
i have 20's w/ the same tire size as you and i have 350z htechs w/ no problems
deanfootlong Nov 20, 2007 11:30 PM
so no camber out of whack?
also, no rubbing of the tires with that low of H tech?
correct me if im wrong... 350z H tech's provide .8 drop in front .6 drop in rear. whereas g35 H techs drop .6 in front. .3 in rear. ??????
thanks a bunch guys.
charles
deanfootlong Nov 21, 2007 10:40 AM
ok i think ive made up my mind on g35 (not z) tein H techs so i only drop my front .6 inches and my rear .3 inches. you think this will look decent with 20's? i dont want a large gap between fender and tire but i dont want to be dropped a bunch.
whats everybodys general consensus on how this will look?
as far as the camber issue, I think i'll be ok with those. if im too far out of spec, i'll get the eibach spc rear camber kit thats 160 or so.
thoughts???...............
SteveBlake Nov 21, 2007 01:16 PM
The G H techs aren't even worth the money IMO... The drop is way too unnoticeable. I would go with 350z H techs.
deanfootlong Nov 21, 2007 03:09 PM
ya, i think im going to. and i think i can get by without getting front camber correction with the 350z H techs. but we'll see how the rear comes out.
Triple8Sol Nov 21, 2007 09:04 PM
350Z H Techs should do the trick, for what you're looking for.
© 2026 MH Sub I, LLC dba Internet Brands
