Help!! SPC Toe Bolt to Short
Just put on my rear SPC camber arms and toe bolts and the toe bolts are to short. I think the reason is my car has Rear Active Steer and the mounting point for the rear midlink is different than a car without it. I think the mounting point is slightly wider. I had to leave off one of the cam washers in order to get it on. That will work for now but I need a longer bolt. I plan on calling SPC on monday.
Has anyone else had this issue and what did you do for a fix.
Originally Posted by G35sedan03
quite a while ago i installed the GTspec rear brace. Later on i got the spc bolt and it was too short. i had to take off the GTspec bar so it would fit. not sure if SPC made a longer bolt. All i needed was about a half inch longer and it would have ben fine.
I called SPC today and they are sending a bolt that is 10mm longer, cars with RAS do require a longer bolt. You could also use that bolt the solve your issue with the GT Spec bar
on
so it took 5 days huh?! oh man, i have the same issue... i called them thursday morning, the guy i spoke to said he's goin to ship out the bolt on that day. so i should expect the bolts on monday? Damn, cant wait to install those bolts, my tires are getting bald already anyways, did you noticed where did the bolts shipped out from?
