G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Brakes & Suspension (https://g35driver.com/forums/brakes-suspension-164/)
-   -   anyone that's lowered...i need help plz.. (https://g35driver.com/forums/brakes-suspension/225970-anyone-thats-lowered-i-need-help-plz.html)
Z_IP_G Jun 7, 2008 08:13 PM
i tried the search button, but couldn't find what i was looking for. i looked in the brake and suspension, but no help either. well, i dropped the front driver side on 350z s-tech, but doesn't seem to be low at all. looks like it dropped a little over 1/2 inch only and i know it's suppose to drop lower than that. before the drop, i had a three finger gap. after the drop, i had a two finger gap. this can't be right, right? i followed the d.i.y on here and everything went smoothly except it wasn't as low as i expected. i did notice that on the chart that came with the s-tech, it says for the g35 you have to cut the rubber bump stop(i believe 1.2" or something like that). the d.i.y doesn't mention anything about cutting the bump stop. am i suppose to cut it? i didn't want to cut it and find out later that i'm not suppose to. do i have to change the other front passenger first to get the right drop? i wanted to make sure first before i do anything to the other side. any help will be greatly appreciated. thanks in advance.
-zee
EDIT: installed all four springs and here's the picture of the before and after. not the best shots, but hope this will do.
before shots:
http://i267.photobucket.com/albums/i...g/before-1.jpg
http://i267.photobucket.com/albums/i...rontbefore.jpg
after shots:
http://i267.photobucket.com/albums/i...ontmeasure.jpg
http://i267.photobucket.com/albums/i...passenger1.jpg
i think it's a decent drop. it's not too low so i don't scrape everywhere i go and it looks nice too.
SteveBlake Jun 7, 2008 08:39 PM
You should try putting both springs on the front and rear (all four)... not just the front passenger... It might go lower that way and it might settle a little after a while. the bump stop is in the front underneath the bumper and im lowered more than your s-techs will go and i didnt touch it.
Z_IP_G Jun 7, 2008 09:31 PM
thanks, i'll try that and see if it helps.
-zee
lniivedl Jun 7, 2008 10:11 PM
it takes a few weeks for the springs to settle..and im assuming you didnt drive around with only the front passenger dropped?
dvsmeth0dz Jun 7, 2008 10:54 PM
finish installing the rest of them and let the springs settle. im sure it'll get lower than 1/2"
MIA BlazinVQ Jun 7, 2008 11:01 PM
my drop on the front with Z s-techs. gaps looks huge but it obviously looks much lower from when you're standing.
http://i234.photobucket.com/albums/e...ioccmeet14.jpg
Z_IP_G Jun 8, 2008 01:34 AM
thanks for the picture. installed all four and drove it around the block a few times. now it's a lot lower now. seems like the front passenger is a little bit lower than the front driver and the back driver is a little bit lower than the back passenger. hopefully it'll even out. i think my gap looks like yours too, but it's dark so i'll check it again tomorrow. i'll try to take some shots tomorrow and post it up. thanks again.
-zee
Z_IP_G Jun 8, 2008 01:40 AM
no i didn't drive around with just one side dropped. i installed it, then dropped the car down and it just didn't look dropped so i was just kind of worried. it looks much better now, with all four installed.
thanks for all your help guys.
-zee
MikeYo Jun 8, 2008 02:07 AM
im glad i didnt get s techs... i would have been unhappy with that wheel gap.
© 2026 MH Sub I, LLC dba Internet Brands
