bump for good info in this thread ..
Originally Posted by IMAFUKINRIDER
(Post 4137090)
Yup both of mine are blown, i noticed when i was putting my car back into street trim. |
Originally Posted by terrasmak
(Post 4137218)
Good info , were all screwed for now. The Nismo and Whiteline bushing are both on backorder till sometime in may.
Yup both of mine are blown, i noticed when i was putting my car back into street trim. bump for a different supplier? |
(Post 4137274)
that sucks ..
Originally Posted by DDD*G35
(Post 4139951)
subscribed for transverse link bushing source... mine is shot - my alignment guy has press... Performance Nissan (mynismo) is within driving distance - I guess I wait till May unless someone finds a source
Havent been around since i sold my G35... i will tell you when i ordered mine they were out of stock also. Told me it would be a month wait, after i ordered it was actually only a 2 week wait and keep in mind if you wait till its "in stock" they will fill the orders that are already waiting before they get to you. So you might as well order the ish now and just get in line since you know that you need it.
Orderedthru 350zmotorsports.com and they are on the way
I bought mine from http://www.jscspeed.com/350z/suspension/wlp_bushings.htm
I have access to hydraulic press but couldn’t find suitable size ID & OD piece of pipe to push out old bushings. What are you using to push bushing without damaging the arm? |
Yea i had that problem as well. I had to grind down a bearing race to press mine in.
Originally Posted by dovla
(Post 4425220)
I have access to hydraulic press but couldn’t find suitable size ID & OD piece of pipe to push out old bushings. What are you using to push bushing without damaging the arm? Use a socket... its the easiest and most common. |
heres a link if u still lookin i found it after i spent 400 to replace that lower control arm the shop screwed me but jus a learnin exp i guess
http://www.g35nyc.com/forums/showthread.php?p=421577 |
^^^ good find :biggthumpup:
Might be easier to link it this way though: http://www.z1auto.com/prodmore.asp?m...ng&prodid=3783 Adam (Z-1) is a good guy – very knowledgeable… his shipping is real fast too! |
Is this for a pair of bushings that would cover both the right and left side? I am just wondering if I need to order 2 to do both sides done.
Originally Posted by OCG35
(Post 4462365)
