G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Brakes & Suspension (https://g35driver.com/forums/brakes-suspension-164/)
-   -   I need help- can't push down brake pedal (https://g35driver.com/forums/brakes-suspension/259022-i-need-help-cant-push-down-brake-pedal.html)
ShanesG Dec 7, 2008 03:03 AM
so I just went to leave to my gf's house and when I go to put my car in gear I can barely move m brake pedal. It's like stuck! If I press real hard it will atop a lil( rolling down my drveway) what could this be! :(
Dustin@StrafeAutomotive Dec 7, 2008 03:06 AM
i would say either no pressure or too much pressure in the brakes.. maybe pocket of air... i got no clue im just throwing ish out there...
ShanesG Dec 7, 2008 03:12 AM
oh fucck I think I know what it is! I'll chime in tomorrow and let you know, since I'm not at home now!
Jeff92se Dec 7, 2008 03:13 AM
Okay, stuck and no braking. Odd. So none of the calipers seem to be moving I assume. That sorta rules out a seized caliper. I'm guessing faulty master cylinder. Especially if it's hard to press when the car is turned off also. ie.. would tend to rule out the brake booster.
Dustin@StrafeAutomotive Dec 7, 2008 03:16 AM
there you go shane. my point exactly:D
ShanesG Dec 7, 2008 03:20 AM
I put some pi thon hose locks on today I think I may have flipped a valve around the wrong way. Cause I was driving the car like 5 hours ago and it was fine!
Dustin@StrafeAutomotive Dec 7, 2008 03:21 AM
yeah check em over again...
Jeff92se Dec 7, 2008 03:28 AM
What? Hose clamps = no braking?
SxExCx Dec 7, 2008 11:55 AM
^yes, check the hose that goes from the plenum to the battery compartment. It has a check valve, so if you put it on the wrong way, it could cause a problem.
k67p67 Dec 7, 2008 11:08 PM
^What Sean said. There are actually 2 check valves in that line but I doubt you touched the one in the brake compartment.
GreenGoblin Dec 7, 2008 11:37 PM
the hose is on backwards dur da dur
ShanesG Dec 7, 2008 11:49 PM
ok well it wasn't what I thought. By the hose I was thinking it was was the one that goes to the evap sensor, it's on the passenger side right below that heater hose, it has that green cap and it says don't exceed 1 psi. Do you think that had anything to do with?
The brakes were perfectly fine when I parked!
I took pics but I'm on my iPhone so if you give me your email I can send the pics if you don't know what hose I'm talking about.
RCMCFE Dec 8, 2008 10:04 AM
This same thing happens to me, but only on cold days during the winter. After I let the car warm up for about 5 minutes, it corrects itself...I haven't messed with any of the hoses.
Anyone?
drsifu1 Dec 8, 2008 10:58 AM
obvious question, but did you try starting your car with your foot on the brakes?
ShanesG Dec 8, 2008 11:38 AM
No^
Im uploading pics right now of what i took off
© 2026 MH Sub I, LLC dba Internet Brands
