Ichibia Rear Camber Kit???
Old 02-21-2009, 09:45 PM
uhyeaimazn's Avatar
can anyone post a template that came with the spc kit if there is one available? i wanna try and see if i can do this myself and see if it works out.
  #32
Old 02-21-2009, 10:26 PM
G35Papa's Avatar
PM me your address and I'll mail one to you.
  #33
Old 02-21-2009, 11:35 PM
Extreme G's Avatar
Can I use the same template from spc camber? I am installing my ichiba camber with toe bolts.
  #34
Old 02-21-2009, 11:37 PM
eurodre's Avatar
woh ur installing ur own rear camber arms? good luck to u, this is were most people fail, most people would get that done by others who have done it before or a shop because its like what.. 30-40 bux for i
  #35
Old 02-21-2009, 11:48 PM
Extreme G's Avatar
I do all the install my self ...
  #36
Old 02-21-2009, 11:53 PM
eurodre's Avatar
i got u, i installed my coilovers and my front arms myself, but hope u know wut ur getting urself into, 30 bux is a small price to pay imo
  #37
Old 02-22-2009, 01:48 AM
Extreme G's Avatar
I did a couple install already. Thank for the advice ...
  #38
eurodre's Avatar
^^ooh ok thats different didnt know that in that case good stuff, juss looking out
  #39
Old 02-22-2009, 01:57 AM
G35Papa's Avatar
Camber kits are a cake walk
Rusty, yes you can use the same template.
  #40
Old 02-22-2009, 01:27 PM
Jobes's Avatar
Need template for toe bolts.
Does anyone know where to find a scan or a download of the template for the toe bolts?? Can I just elongate the holes without a template?
G35papa.... do you think you can help me out too?
  #41
Old 02-22-2009, 03:11 PM
G35Papa's Avatar
Sure...shoot me a PM
  #42
Old 02-22-2009, 08:37 PM
Extreme G's Avatar
Just got done installing the camber kit and toe bolts. Now my back hurts..
  #43
Old 02-22-2009, 08:55 PM
AARONHL's Avatar
Why are the SPC toe bolts machined flat on one side? Is there a certain way to position them in?
How do I know how much to turn the adjuster on the SPC camber arms when I install them? Give the wheel a zero camber look and have the alignment shop adjust even further?
  #44
Old 02-22-2009, 11:21 PM
redlude97's Avatar
They are machined flat on one side for clearance as you rotate them around the eccentric washer. Set the camber arms to the same length as the stock arms with equal threading on each side and then get an alignment
  #45
Old 02-23-2009, 12:30 AM
AARONHL's Avatar
Thanks for the reply! What washer are you talking about? I'm trying to picture this in my head before I install all of this.
Quick Reply: Ichibia Rear Camber Kit???
