Anyone have 350Z GF210's WITH the OEM Rays 19's?
I have the 350Z GF210's with stock 17's. Upgrading to the OEM Ray 19's. Want to see what to expect. thanks |
anyone?
Well here are some pics since supposedly no one has ever done it.
http://i22.photobucket.com/albums/b3...2372RESIZE.jpg http://i22.photobucket.com/albums/b3...2380RESIZE.jpg http://i22.photobucket.com/albums/b3...703bRESIZE.jpg http://i22.photobucket.com/albums/b3...1703RESIZE.jpg http://i22.photobucket.com/albums/b3...703cRESIZE.jpg |
Sorry to slighty thread-jack but I'd always wondered about these GF210 springs too compared to the 350z tein s-techs. It offered a slighty lower drop than the teins. The DF210 was too low and too soft, and the NF210's had an ideal drop but too soft.
350z Tanabe GF-210 Design: Linear F & R F Drop: 25mm (1in)(+/-.5" more on the G35) R Drop: 30mm (1.2in)(+/-.5" more on the G35) F Stiffness: 6kg/mm (335lb) R Stiffness: 6.7kg/mm (374lb) 350z Tein S-techs Design: F: Progressive R: Linear F Drop: 17mm (.7in)(+/-.5" more on the G35) R Drop: 14mm (.6in)(+/-.5" more on the G35) F Stiffness: 6.9kg/mm (386lb) (+23%) R Stiffness: 7.2kg/mm (402lb) (+16%) BTW, That's a nice drop on those oem 19's :biggthumpup: |
you realize that if you use the 350z springs on the G it gives you additional .5' drop? That is why i chose this setup, gives you the ride quality and the drop when you choose the 350z version
^ oh yeah, i'm aware of that. I just posted the specs for 350z to maintain a set comparison. I'll update and put a note beside the drop measurements.
Another thing is, the 350z s-techs usually require for the spring mount mod/cut to get rid of the nose dive effect. With yours, it seems nicely balanced out already. I'm just hoping the GF210's has just enough stiffness to justify it's drop, to prevent bottoming out and premature wear on the oem shocks. |
Originally Posted by skahide
(Post 4472017)
Originally Posted by Deezflip
(Post 4472009)
350z Tanabe GF-210 Design: Linear F & R F Drop: 25mm (1in)(+/-.5" more on the G35) R Drop: 30mm (1.2in)(+/-.5" more on the G35) F Stiffness: 6kg/mm (335lb) R Stiffness: 6.7kg/mm (374lb) 350z Tein S-techs Design: F: Progressive R: Linear F Drop: 17mm (.7in)(+/-.5" more on the G35) R Drop: 14mm (.6in)(+/-.5" more on the G35) F Stiffness: 6.9kg/mm (386lb) (+23%) R Stiffness: 7.2kg/mm (402lb) (+16%) BTW, That's a nice drop on those oem 19's :biggthumpup: Would have been a lot easier to simply cut and paste the specs from here https://g35driver.com/forums/brakes-...w-updates.html Tanabe GF210 Series 350Z progressive springs 1”/1.2” drop on 350Z G35 drops will be higher Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown) Tein S-tech 350z (fronts are progressive, rears are linear) .7”/.6” drop on 350Z G35 drops will be higher Spring rates in LBS 386/402 (estimated front intial rate is 327lbs) |
^yeah I pulled those specs from an old post originated from 350z-tech.com. I never checked to see if it was updated or not.
Anyways, from your previous post, having revised 350z shocks, or the others mentioned, you think the GF210 would perform fairly well compared to the 350z stechs? And would you say that the 350z stechs would also require the revised 350z shocks as well? |
| All times are GMT -4. The time now is 07:37 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
