Who makes a 2-piece drilled or slotted that fits OEM Brembo's?
Old Jan 10, 2010 | 06:02 PM
WhiteonWheat's Avatar
Question Who makes a 2-piece drilled or slotted that fits OEM Brembo's?
I'm looking for a light weight 2-piece drilled or slotted (or both) rotors to replace my old OEM. I have the OEM Gold Brembo's. I've looked and looked and see plenty of 1-pieces, but haven't found any 2-pieces.
Any help would be greatly appreciated fellas!
Thanks Guys!
-WoW
Old Jan 10, 2010 | 06:18 PM
SDGenius's Avatar
2pc front & rear:
- Stoptech
- RacingBrake
- Girodisc
2pc front 1pc rear:
- DBA
- Project Mu
2pc fronts only
- Endless
Old Jan 11, 2010 | 06:12 PM
^ Awesome info - Thanks SDGenuis. Are you running 2-piece or 1 btw?
I'm wondering how much difference I'll feel in braking power, and reduced unsprung weight (get up and go performance)?
What do you guys think?
Thanks Guys!
-WoW
Old Jan 11, 2010 | 08:51 PM
SDGenius's Avatar
i just picked up OEM Brembo's, haven't installed yet. I orederd DBA 2pc fronts w/1pc rears. i really liked the looks & price of the setup. the wieght savings in the rear isn't as much as the front because of the retention of the parking brake. the 2pc all around setups are nice, but will run you bit more and have more of a toned down look. I liked my setup since the hats are gold and the drill & slot design are pretty different.
you won't feel more braking power, it'll just "fade" less because of the cooling. you will feel the unsprung wieght. just like when you put on lighter wheels, it'll pull nicer.
Old Jan 12, 2010 | 05:54 PM
^ Great info again!
Please let us know how the OEM Brembo's and DBA install goes and post pics if you can!
Good luck and hope it (install) all goes extremely well for you.
Thanks Guys!
-WoW
Old Jan 12, 2010 | 05:59 PM
bonker008's Avatar
Go see Stillen website. http://www.stillen.com/
Old Jan 12, 2010 | 06:02 PM
SDGenius's Avatar
stillen doesn't offer 2pc rotors for OEM replacement
Old Jan 12, 2010 | 06:06 PM
SDGenius's Avatar
Originally Posted by WhiteonWheat
^ Great info again!
Thanks Guys!
-WoW
thanks, yeah... the DBA's aren't a very common choice. most people just run 1pc xdrilled/slotted. i've seen a few run the Project Mu 2pc + 1pc setup and one w/Girodisc 2pc all around. the stoptechs are prob the best performers but are also the most expensive.
Old Jan 13, 2010 | 12:48 AM
bonker008's Avatar
Correction SDGenius. If you look at the DBA 5000 Series Two Piece Sport Rotors - Pillar Vane from Stillen, they do offer 2 pc rotors for 2003-2004 Infiniti G35 2DR Track Model w/OE Brembo Calipers. Unless I'm reading this incorrectly.
http://www.stillen.com/product.asp?i...odel=G35%202DR
Old Jan 13, 2010 | 12:56 AM
SDGenius's Avatar
yeah, those are DBA's not Stillens.
Old Jan 14, 2010 | 11:38 PM
SDGenius's Avatar
pic of my setup
Old Jan 15, 2010 | 03:39 AM
bonker008's Avatar
SDGenius, Please note I said "Go see Stillen website. http://www.stillen.com/". I did NOT say Stillen makes the DBA, but they do sell them. I know because I bought my DBA from Stillen.
Old Jan 15, 2010 | 04:08 AM
SDGenius's Avatar
sorry, hear that... you must have over paid then
Old Jan 16, 2010 | 08:59 AM
^ Ok, guys, calm down some. he he. We're all friends here, and there is GREAT info being shared - so let's all enjoy learning and sharing (especially me - learning that is!). SDGenius - FANTASTIC looking setup my friend - I like the gold caps with the gold Brembo's - CONGRATS and enjoy the he*ll out of those bad boys!
I think I'm going to go 2-piece front and rear - mind as well go all out - since I'm going to try and keep the coupe for another 5-8 years (depending on how well the engine holds up and knock on wood that no one runs into her - that would suck!). I want the 2-piece setup on the front and rear to see (for fun) how much improvement in "pick up and go" I'll get out of the reduction in un-sprung weight - plus the added cooling factor and the ability for the rotor to flex more freely which will help reduce warping over time. (See I'm trying to do my homework and learn! HA!)
Keep the setup's coming - I would LOVE to see more!
Thanks Guys!
-WoW
Old Jan 16, 2010 | 09:29 AM
SDGenius's Avatar
2pc all around setups:
GiroDisc
***Note's: rear pads must be trimmed, but you can get them pre-trimmed from GiroDisc. rear design maintains max weight savings and keeps parking brake
RacingBrake
***Note's: cast iron rear hats keep OEM parking brake in spec, but does not give max weight savings
Stoptech
***Note's: offers both drilled only & slotted only options, but most expensive and rotors are "made to order"
