new pics of my G35C with Tanabe GF210 springs
Old 08-05-2005, 01:31 AM
enzo's Avatar
Originally Posted by Triple8Sol
I was looking into these springs too, but was worried how much more it would drop over the Z. So you're saying it was an extra 0.8" of drop in the front? I'm wondering if you might as well have gone with the DF210 for the G35c and got a much more comfy spring rate?
How much of a stiffer ride you want will be up to you; I wanted a stiffer than stock ride. The drop is the best I've seen any spring set give.
Old 08-05-2005, 03:54 AM
truplay8's Avatar
THE BATMOBILE
very nice drop
Old 08-05-2005, 05:59 AM
blazinZ's Avatar
thats like the perfect drop, imho
Old 08-05-2005, 06:26 AM
enzo's Avatar
thanks
Old 08-05-2005, 06:32 AM
enzo's Avatar
The G and Z has almost the same weight so I'm not sure why the springs are sitting lower than specified. I'm afraid to say that my 1.8" drop measurement was only an eyeball guess. The drop is not that low. There's about a 1/4 inch gape between the top of the tires and the fender if you looked at it dead on. The drop could very be 1.0".
Old 08-05-2005, 08:20 AM
kenchan's Avatar
I like the clean look. that rear imho looks a bit too low vs front.
Your rear should be slightly higher than front if you want turnability,
not sure if that's what you were going for or not.
Do you have a stereo in the trunk?
edited for better explanation...
Old 08-05-2005, 08:22 AM
kenchan's Avatar
your rear is flat with the front.
Old 08-05-2005, 12:00 PM
transportchef's Avatar
Looks nice.
Old 08-05-2005, 01:23 PM
//m-zilla's Avatar
looks like its a$$ draggin stick with eibach or H&R.
Old 08-05-2005, 03:23 PM
enzo's Avatar
the drop is even front to rear. i like my cars like that. it just depends on your tastes.
Old 08-05-2005, 03:30 PM
player's Avatar
looks good man
Old 08-05-2005, 07:32 PM
kenchan's Avatar
yep. or just a coincidental result.
Old 08-05-2005, 08:59 PM
blazinZ's Avatar
are you getting anything to adjust camber or how far off were your numbers is it ok is what i'm asking..
Old 12-03-2007, 09:57 PM
sammy_G's Avatar
I installed these springs last week and so far.. i really like them
I also installed a rear spc camber kit (knew I'd need it) and cusco sways. Even with the camber kit my rear arms are at full adjustment and the alignment is just barely within spec.
edit: i just noticed your front end looks a slightly higher than mine. I'll have to post some pics
  #30
Old 12-04-2007, 01:56 AM
TurK's Avatar
how is it that an after market rear camber kit barely being enough to adjust the camber?
Quick Reply: new pics of my G35C with Tanabe GF210 springs
