E Brake light Problem!! Help
Hey everybody, looking for a little help..
When i brake hard on my car going pretty much any speed my E brake light on my dash will come on like i have pulled up my E brake. Has anybody had this same problem? anybody have a fix ?? |
check your brake fluid it may be low.
Ill have to check that out first... Anybody else got any ideas ??
Maybe the shoes for the ebrake need to be adjusted? They fit inside the back rotors. There is an adjustment wheel for the shoes that you can loosen or tighten behind the rear rotors as well.
(Post 5051983)
Maybe the shoes for the ebrake need to be adjusted? They fit inside the back rotors. There is an adjustment wheel that you can loosen or tighten behind the rear rotors as well.
Good to know. Where is the sensor located on the 6MT and the 5AT? By the handle or pedal?
they both have the switches mounted at the actual lever.
