G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Brakes & Suspension (https://g35driver.com/forums/brakes-suspension-164/)
-   -   diy'er thinking about replacing bushings (https://g35driver.com/forums/brakes-suspension/373648-diyer-thinking-about-replacing-bushings.html)
HITMANVQ35 Apr 13, 2011 07:35 AM
I need to replace my bushing in the front control arm. Is there a DIY or any instructions out there that tells you how to do this?
My tires are worn bad from the worn bushings, esp inside treads.
obender66 Apr 13, 2011 03:24 PM
I'd say no, unless you have press or air tools. It is max 1.5 hrs of labour at the shop+alignment, just pay for it.
Otherwise instructions are simple: take front control arm off, get old bushings out, put new bushings in.
datbeans Apr 14, 2011 03:02 PM
He's right its really easy i only used the manual for tourqe specs...
Helpful hint PB Blaster the shizz out of the bolts, I even had to borrow one of those
electic tourqe wrench to help me on a few of the bolts.
How are you planning to press in the new bushings? I paid a local shop to press in the new bushings for me and just tipped them 10 bucks..
Heres a diy from Jason to help you
http://my350z.com/forum/brakes-and-s...translink.html
Deezflip Apr 14, 2011 03:45 PM
^nice find, looks like if you can change a wheel bearing(rear bearing, not the front wheel bearings, they were too easy)....you can do this DIY.
OP are you sure you don't just need a wheel alignment? Although worn bushings can result tire wear, you should notice a shake on high speeds and problems tracking the car straight also.
AuAltima3.5 Apr 15, 2011 03:03 PM
There's a 350z website I won't mention that has a great DIY for this.
An electric impact is a must for suspension work. I wouldn't attempt it without one.
It took me about four hours to get this done, but I had to drive to a shop and let them press them out/put the new in, plus lunch ;).
Super easy, just time consuming. Those cotter pins were a bish to remove, too.
© 2026 MH Sub I, LLC dba Internet Brands
