front LCA bushing recommendations
Old Sep 26, 2011 | 08:36 AM
whoisthis's Avatar
The right front wheel area has been creaking and clicking for awhile. Maybe it's time for knew LCA bushings.
What is the difference between whiteline and energy suspension bushing?
I will choose between those two brands for the outer LCA bushing (where lower shock mount mounts to).
For the inner bushing, will i feel a big difference between SPL (solid bushing), and whiteline and energy?
Old Sep 28, 2011 | 09:12 AM
got_boost99's Avatar
Subscribed. I have the same questions. Actually doing some search on it. I wanted to go with SPL, but funds are low at the moment and I'm not sure if it'll be noisy or a lil too harsh... Looking for ppl with experience having both polyurethane and solid mounts to chime in...
Old Sep 28, 2011 | 03:31 PM
hologram's Avatar
Energy suspension if you look in this suspension forum there is a guy who posted a review of the master bushings set and a review of the front bushing kit.
Old Sep 28, 2011 | 03:59 PM
whoisthis's Avatar
ive seen that thread. is there a comparison between energy and whiteline?
Old Sep 28, 2011 | 04:08 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
If you don't mind noise, then get the SPL's, they tighten up the steering quite a bit and give a better road feel through the steering wheel.
Honestly though, the whiteline or energy are your best bet. Most people can't deal with the NVH produced by the SPL's.
If you get the whiteline for the Inner LCA you might as well replace the shock mount bushing on the LCA while it's already off the car, takes an extra 5 mins and it's better to replace now than later.
Old Sep 28, 2011 | 04:09 PM
They're essentially the same thing, both polyurethane bushings, the only difference is the Whiteline comes with a steel sleeve around the bushing like the oem bushings where the energy does not.
Old Sep 29, 2011 | 01:12 AM
whoisthis's Avatar
most likely i'll get SPL for inner bushing and polyurethane for outer bushing.
i heard too many people having problem with NVH from outer SPL bushing.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
rping
Jul 26, 2015 09:53 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
