E-Brake Replacement (Cannot just adjust)
I have a 2006 G35 Coupe Manual.
The E-brake has been tightened by the dealer over and over and now the cable is stretched and I need to replace the shoes and such. It has new rotors on the car. Does anyone know where I can find a E-brake kit? Does anyone know where a write up is? Looking to do this sunday. Thank You, |
in case you haven't already done it this might help
http://www.nicoclub.com/FSM/G35/Coupe/2006_G35_Coupe/ click on "pb" for parking brake fwd has the index in it |
I did it not too long ago, real pain in the butt.
It was my first time doing drums. Anyway, one of the hardest things for me was getting the rear rotors off. They were stuck on there pretty good (obviously make sure your ebrake is off!) I adjusted them in the back, then tightened the cable a week later after everything set in. When adjusting the rear shoes, remember which way (up or down clicks) tighten them! I.forgot and had a long trial and error before I got it right. While you're in there you might as well change your rear pads if you haven't decided to do that already. |
