Track pack Brembo's on G35X
Hey guys,
So, I did a search but I'm notorious for not seeing threads that are about the same topic. I used to own a 240sx S14 and made adaptors for ctsvbrakeswap.com to (obviously) put cts-v brembos on the s13, s14, and z32. This being said, now that I own a 2005 G35X, I want big brakes. Since the 350z track pack came with the 12.75" rotor and 4 piston caliper, that'll be easiest for me to do since it won't require a bracket. Here is the question, though. Is the knuckle the caliper bolts to the same on a G35X as the G35 and 350z? Thanks! :icon40: |
I would imagine so but can't say for sure
Good question I've seen Akebonos on an x but subd to find out as well |
I'm 99% sure the spindle/knuckle is the same between the AWD and RWD G35. I've seen pics of the RWD version which contains the "pass-thru" for the front CV axles on the AWD cars.
Now, whether or not that's the same as 350Z I am not sure. From pics...it's looks the same |
(Post 7033674)
Originally Posted by Mustang5L5
(Post 7033690)
Q - What brake upgrades are available for the sedan?
The sedan's brake options are the same as the non-brembo coupe (or 350Z) *Note the 05 AWD still has the same brakes as the 04 RWD. Found this in the FAQ's |
There are two other things i'd worry about.
#1) will the rims on your car clear the calipers. SInce they are 4 piston calipers, I'd imagine they would stick out a bit on each side of the rotor. If your G35x is wearing stock rims, they may hit the spoke. #2) master cylinders are usually a ratio of master cylinder piston area vs slave cylinder (caliper) piston area. If you change the calipers to one with 4 pistons, does the surface area of the piston change? This would take a bit of math, but I'd reseach the master cylinder diameters of the 350Z with track pack, vs a stock G35x and see how they compare. From personal experience, the difference of 1/16" in MC bore size can make a huge difference in how the brakes feel. Since I have not heard of someone doing this exact swap, unsure if they performed an MC swap to compensate. BTW, I have swapped brake systems on other cars from a special model, and an MC swap was required to make the brakes workable, that's why I addressed it as a concern in my mind. |
(Post 7034097)
#1) will the rims on your car clear the calipers. SInce they are 4 piston calipers, I'd imagine they would stick out a bit on each side of the rotor. If your G35x is wearing stock rims, they may hit the spoke. #2) master cylinders are usually a ratio of master cylinder piston area vs slave cylinder (caliper) piston area. If you change the calipers to one with 4 pistons, does the surface area of the piston change? This would take a bit of math, but I'd reseach the master cylinder diameters of the 350Z with track pack, vs a stock G35x and see how they compare. From personal experience, the difference of 1/16" in MC bore size can make a huge difference in how the brakes feel. Since I have not heard of someone doing this exact swap, unsure if they performed an MC swap to compensate. BTW, I have swapped brake systems on other cars from a special model, and an MC swap was required to make the brakes workable, that's why I addressed it as a concern in my mind. I will check on the master cylinder dimensions as well. Thank you for the suggestions! |
(Post 7034097)
https://cimg5.ibsrv.net/gimg/g35driv...a727e708f7.jpg
I bought some remanufactured 04 G35 coupe brembos and just had them repaintws dark silver metallic with red brembo decals. Im installing these on my 06 G35x. Yes they do fit. Its a direct swap without adapters. Even the caliper bolts are the same. But the rear requires the coupes caliper bolts. Also the front and rear requires the coupes brake lines from the coupe with Brembos. You cant use the stock G35x lines. I just upgrades to stainless steel lines instead. |
Also the master cylinder is the same on the sedan as the coupe with Brembos. So no need to even second guess.
| All times are GMT -4. The time now is 12:23 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
