Replacing All Suspension
Are you trying to do an OEM refresh or coilovers/slammed/camber kits galore? I did an OEM refresh earlier this year and can give the full list of parts, was able to get 80% of it from rockauto.com.
You have some homework to do if building an aftermarket suspension setup.
245/35/20 Front 285/30/20 Rear
i would like to know what you paid for that
Here's the LoSt180 suspension overhaul shopping list. This was done Feb-Mar of this year.
2006 INFINITI G35 3.5L V6 RWD Coupe w/ Sport susp
Brand | Part Number | Part Type | Price EA | Quantity | Total
ACDELCO | 45G20657 | Stabilizer Bar Link | $ 18.20 | 1 | $ 18.20
ACDELCO | 45G20658 | Stabilizer Bar Link | $ 18.20 | 1 | $ 18.20
ACDELCO | 45G0346 | Stabilizer Bar Link | $ 20.79 | 1 | $ 20.79
ACDELCO | 45G0345 | Stabilizer Bar Link | $ 20.79 | 1 | $ 20.79
KYB | 344455 | Shock Absorber | $ 33.79 | 2 | $ 67.58
KYB | 341367 | Strut | $ 81.79 | 1 | $ 81.79
KYB | 341366 | Strut | $ 81.79 | 1 | $ 81.79
MEVOTECH | CMS30165 | Control Arm (front lower rearward/compression) | $ 54.79 | 1 | $ 54.79
MEVOTECH | CMS30166 | Control Arm (front lower rearward/compression) | $ 54.79 | 1 | $ 54.79
MEVOTECH | MES80579 | Tie Rod End | $ 19.68 | 1 | $ 19.68
MEVOTECH | MES80578 | Tie Rod End | $ 19.82 | 1 | $ 19.82
MOOG | K160011 | Shock Mount | $ 11.10 | 2 | $ 22.20
MOOG | K160105 | Strut Mount | $ 30.79 | 2 | $ 61.58
SPD | 1010163-S5 | Front Knuckle Lower Control Arm Ball Joint w/ Seat - Infiniti G35 05-06 Sedan, 05-07 Coupe V35 | $ 69.95 | 2 | $ 139.90
(Ball joints purchased from Concept Z Performance as they were the only one that had proper fitment for 05+, can get from rockauto if have an 03 - 04 model)
Total: $ 681.90
Other parts to finish out the front are (my front control arms already had Whiteline bushings, so I didn't need these):
MEVOTECH | CMS30161 | Control Arm - Front Left Upper; RWD | $ 45.99
MEVOTECH | CMS30162 | Control Arm - Front Right Upper; RWD | $ 45.99
MEVOTECH | CMS301030 | Control Arm - Front Left Lower Forward; RWD | $ 65.97
MEVOTECH | CMS301031 | Control Arm - Front Right Lower Forward; RWD | $ 65.97
Adjustable Camber Arms:
SPC Front and Rear
Optional stuff (did parking brake with rear bearings):
CENTRIC | 11107830 (111.07830) | Parking Brake Shoe | $ 12.67 | 1 | $ 12.67
CENTRIC | 11842023 (118.42023) | Parking Brake Hardware Kit | $ 11.69 | 1 | $ 11.69
TIMKEN | BM500006 | Wheel Bearing & Hub Assembly (rear) | $ 40.99 | 2 | $ 81.98
Car has over 200k miles. I also did a complete tuneup, including NTK O2 sensors, plugs, and all fluids. Overhaul got rid of many noises and clicks and creaks and rides like a new car all over again.
Total: $ 681.90
SPC Front and Rear
The following 5 users liked this post by LoSt180:
ashtheblunt (12-14-2016),
cenzo6mt (10-25-2016),
cleric670 (04-20-2018),
FreshLikeAG (04-21-2018),
tball35 (10-29-2019)
Hey guys, I'm trying to replace all my suspension parts to get a smoother and improved handling ride for a daily driver cruiser. 2006 Infiniti G35 Coupe. I'm beginning on suspension to full restore the G.
Just need help. Anyone wanna name every part/or a list of what parts I'd need? Or suggestions/recommendations?
These guys can show you which suspension is best for whatever application, but if you want handling, get some bars and cross braces as well.
The best mods you can do to improve handling are the sway bars and tires, then struts.
I drove ttrank's car solo
Received 1,486 Likes
on
on
Swaglife81
07-21-2020 06:13 PM
Jaayford
09-29-2016 09:26 PM
