Bilstein B8s for 350z
Hey all im wondering if i made a goof up or not. Long story short im piecing together suspension setup for my 04 coupe so far im looking into getting the following;
https://www.z1motorsports.com/z1-pro...e-p-12166.html and https://www.tirerack.com/suspension/suspension.jsp?make=Bilstein&model=B8+Performance+ Plus+Shock&group=B8+HD+Shock&partNum=24-101561&autoMake=Infiniti&autoModel=G35+Coupe&autoY ear=2004&autoModClar=Performance+Wheel%2FTire+Pkg and https://eibach.com/us/i-2032-pro-kit...4-springs.html (The setup is Bilstein B8s for 350z and Eibach Pro lowering srings for G if you dont want to check the links) im looking for 1.5 inch max drop, my question is will i drop more than i want with this setup as the struts are shorter and for a 350z? will this setup work with the G/together? |
correct me if i'm wrong, but I think it is the springs that are shorter for 350z models and not the shock body right? The eibach pro-kit is a very mild drop and paired with any aftermarket shock should get you roughly to the height you're shooting for after springs settle a bit. if you're really that dead set on having a 1.5" drop, you should have gotten height adjustable suspension like the Tein Basis Z which iirc is like $480.
i was under the impression the B8s are a half inch or inch shorter than the B6's which are stock length. The eibach pro kit says 1.1 inch drop. Im not looking for 1.5 exactly, i just didnt want it super slammed
Results of quick google search: https://g35driver.com/forums/wheels-...g35-sedan.html
it's talking about stock 350z struts but the Bilstiens for the 350z are the same spec so this applies. My 2 cents, just use KYB struts for the G with the pro kit and spend the money you saved elsewhere in your suspension (bushings, swaybars, etc depending on what you have done). Either that or go straight to coilovers. |
thanks for the advice but im already a little comitted now (drunken purchases) i just wanted to be sure im not slamming the **** out of my car even though ill be getting adjustable arms. I bought both B8 rear struts and pro kit for $355, I can get both fronts for $400 off amazon which is all i need
Originally Posted by SoCal04G35
(Post 7155104)
thanks for the advice but im already a little comitted now (drunken purchases) i just wanted to be sure im not slamming the **** out of my car even though ill be getting adjustable arms. I bought both G8 rear struts and pro kit for $355, I can get both fronts for $400 off amazon which is all i need
