Corner balancing.....
For those of you in the GTA on coils, have you considered corner balancing the car?
Reason for asking is, I'm considering the purchase of a set of car scales. I'm primarily looking at them for my own use, since I play around with set up so much. I also wouldn't mind offsetting a little the investment cost if there was any interest. Just curious :) |
I think corner balancing is a good investment.
I'm getting my coils put on next week and I'm having my wheels corner balanced. I'm just not sure if I need to wait until the coils settle or does it really not matter. |
i installed and adjusted them myself so im sure corner balancing would be a plus lol. How far are you from brampton
Corner balancing is primarily for handling performance.
If your primary concern is stance, then you might not want to do it. Basically, you set the heights where you want them, then corner balance from there. You tweak the height a bit based on the scales to get your corner to corner weights close to 50/50. |
Originally Posted by BashaZ
(Post 5778302)
Sasha from SG-Motorsport does it for $100 an Hour....usually it doesn't take longer than that
Ed from Advanced PowerHouse (APH) Does it for $80 an Hour and $20 for 15 minutes after that. Again, it shouldn't take more than an hour. So I do not know if it is worth it for you to buy the scales |
Thanks.
Some BMW shops are charging $450, which I thought was insane for what it is. |
it would helps primarily getting equal heights all aroundd
Originally Posted by InTgr8r
(Post 5778366)
Thanks.
Some BMW shops are charging $450, which I thought was insane for what it is. SG-Motorsport and APH are both very reputable shops when it comes to Gs and Zs. |
+1 on sg
I've see Sasha at the track, sounds like the best option to me.
https://g35driver.com/forums/canada/...day-track.html http://sphotos.ak.fbcdn.net/hphotos-..._8240128_n.jpg |
Yeah, he's a beast on the track...he's also a really nice guy.
If you go to him tell him Matthew with the 350z sent you |
^Will do.
Sasha logs in here once in a while too. :) |
Let us know what set up you're looking to adjust. ;) :biggthumpup:
my friend use to work for sasha last year(joe). he helped with the race team and setting up the cars for track days. he pointed out the advantages of corner balancing cars.
