zaio and z5 pro
is zaio a wax? i have both zaio and z5 pro and i have been putting z5 pro on after Zaio, am i doing the right thing? or should i be putting z5 pro first then Zaio?
I am assuming you are referring to Zaino Z-All In One (Z-AIO). You should always apply Z-AIO first and then Z5Pro. If you do it in reverse order you'll be basically stripping off the Z5Pro with Z-AIO which has some cleaning properties.
You can refer to the Zaino website for more info - here is the link to Z-AIO (there's an FAQ on the bottom of the page): http://www.zainostore.com/Merchant2/...uct_Code=Z-AIO Of course with any detailing project good prep-work is a must. |
As others said...ZAIO then topped with Z5.
Zaino is a sealant though, not a wax. |
