meguiar's direct deep crystal sytem
i was wondering if anyone used the Deep CrystalŽ System Paint Cleaner, Deep CrystalŽ System Polish, and Deep CrystalŽ System Carnauba Wax and how it worked out for them. is it worth it?
Seriously, if your paint is in great condition, that can make it look good. However, that system will not remove swirls or marring. I would look into products that will remove swirling and marring rather than that kit.
I've personally used the kit and was not too impressed. There are much better combinations to be had.
I would suggest a generic clay bar, Optimum Polish, and Migliore: Original blend wax. You can find our wax at www.migliorewax.com. Let me know if you have ANY questions. |
im only limited to stuff around town like autozone and stuff so i really cant get ahold of better products.
If you cannot order anything online, go to Autozone and get a clay bar. They have either Mother's or ClayMagic. Read the instructions and clay your car. This removes surface contaminents stuck in the paint. Make sure you keep the area wet with the spray that comes with. Then use the system you were planning on using. It won't remove the swirls, but it should look better.
| All times are GMT -4. The time now is 10:01 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
