What's good for weather stripping and trim protectant?
What do you guys use that would give a good protection from the elements for all the rubber weather stripping around the doors, trunk and hood area, seal around the sun roof etc.:icon43:
Anyone?
Armoral original protectant is something I've seen recommended and I've been using that once a year. I spray it on a cloth and wipe on to apply. Difficult to get all the moonroof rubber.
just heard pros and cons about Armoral, hummm....
I use zaino z16, its meant for tires, but they reccomend it for exterior plastics and rubbers as well.
I tried it out, but it looked really weird when it got wet, but maybe thats because it didn't have enough time to dry, which could also be because I might have applied a little to much. next time I'll try to give it a full 24 dry time, and apply more thinly. I think you can use aerospace 303 as well, haven't tried it on that stuff yet, only on dash, its nice, deepens the colour a bit. |
Anything else out there that's good?
I use silicone spray on the door and window seals, trunk and hood seals. just spray onto a rag and wipe on. let set for a couple of minutes and then go with a clean rag and wipe off any excess. it'll leave a nice dry smooth slippery finish that lasts a long time and prevents the rubber from drying out. I've tried 303 but it doesn't last as long on exterior parts subject to the weather.
just make sure you don't get it on the paint or windows, as it takes a bit of effort to remove. |
Originally Posted by headshot
(Post 4970258)
Stay away from silicone based products, over time they will dry out and crack rubber, leather and vinyl surfaces. Most silicone based products are a no-no in the detailing industry. |
http://www.detailersdomain.com/1zein...carestick.aspx
Clean the oxidized rubber before treating anything, do this with paper towels/rags and diluted Isopropyl Alcohol(aka IPA, found at any CVS, Rite Aid, etc for a couple bucks.) |
Originally Posted by Detailed Image
(Post 4978482)
http://www.mpt.org/motorweek/goss/2831.shtml It is also recommend for use on door seals by the manufactures of silicone sprays. it says to keeps gaskets loose and prevents wear and cracking. http://www.liquidwrench.com/products...icone%20Spray/ |
I use Leatherique once a year to restore all of the trim and maintain it with Poorboy's Natural Look dressing. It leaves a nice clean OE looking matte finish and dries well without leaving a greasy feel to everything.
some good ideas!
I have had a lot of success with 1Z products......they have a few items that will work
Originally Posted by DHCrocks
(Post 4979056)
hmmm strange I've always heard to use silicone spray on the door gaskets. I know on motorweek Pat Goss recommended it on the door seals, sunroof gaskets.... I can't find the link for that but found this one that address the gaskets for convertible tops.
http://www.mpt.org/motorweek/goss/2831.shtml It is also recommend for use on door seals by the manufactures of silicone sprays. it says to keeps gaskets loose and prevents wear and cracking. http://www.liquidwrench.com/products...icone%20Spray/ Just my $.02. |
I decided to go with Lexol conditioner. Put it on yesterday and it left a nice finish. None greasy, non shiny look. It gives a good UV protection and its the same stuff I use for my leather.
| All times are GMT -4. The time now is 11:24 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
