Sonax Full Effect Wheel Cleaner, Adam's APC, Prima Nero/Wheel Armour in action
Old Aug 19, 2010 | 10:54 PM
DetailersDomain's Avatar
Sonax Full Effect, Adam's APC, Prima Nero and Wheel Armour in action.
Figured I would post how these all work together.
These dirty Audi Q7 S-Line wheels (about 1 month of brake dust) were cleaned with Sonax Full Effect Wheel Cleaner (no brushes where used, just a pressure washer and the wheel cleaner). The tires were cleaned up with Adam's APC. After the rims and tires where dry, we applied Prima Nero on the tires for a satin finish. Prima Wheel Armour to them for a durable finish and nice shine.
Wheels were extremely caked up with brake dust
Sonax Full Effect Wheel Cleaner in action!
Adam's All Purpose Cleaner does a very effective job of cleaning all the grime off the tires, readying them for dressing.
Clean wheels and tires
Prima Nero and Wheel Armour to finish them up.
Final results look impressive!
The products used above are listed below.
Prima Nero
Prima Wheel Armour
Old Aug 19, 2010 | 10:57 PM
WhosRich's Avatar
Did you clean the barrels?
Old Aug 19, 2010 | 11:01 PM
yes they were cleaned.
Old Aug 20, 2010 | 01:31 AM
WhosRich's Avatar
If you had to compare sonax and Meguiars WB in terms of strength, which one is better?
Old Aug 20, 2010 | 01:49 AM
WB has acid in them which under the wrong hands would be bad for the finish on your wheels.
I would say that Sonax Wheel Cleaner is the best non acid based product for wheels
Old Aug 20, 2010 | 06:27 PM
djfarhan's Avatar
great job!
Old Sep 5, 2010 | 09:06 PM
thanks!
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Tylerttn
Jul 16, 2015 10:33 AM
