Another window motor thread..
I figure by now we have some experts around Dallas that may be able to assist me with this. It happend this afternoon on my lunch break, started making weird clicking noises when I went to raise it up. It went down then stuck half way I tried to pull it up.. then it went back down.. it went a little up then all the way down and hasnt come up since.
I havent done anything except mess with the buttons. Any suggestions? All I can come up with is to take the door apart and try the reset or just get to ordering a window motor. Crest Stealership is asking like $530+ to fix it. :mad: This couldnt have come at a worse time, im starting to dislike this car.. |
do a search one of our Local members "G35Man04" did a DIY
https://g35driver.com/forums/body-in...l-removal.html |
Originally Posted by Princedrama
(Post 5463425)
So im thinking that If I have to go into the door, I may as well try to find a window motor so in case it isnt fixable I can just replace it. I found this:
Im open to any suggestions. If any one else has any suggestions as to a best place to source the parts or if I should just try the reset -if its worth going through all that to get to it only for it not to work.. |
Craziest **** ever.. I tried just opening and closing the door while holding the switch in the 'up' position.. it friggin worked!
Only thing is Im hoping it will stay working, I dont know if it was a glitch or if the ****s about to break on me again. Guess Ill just have to wait and see. |
I can fix it (btw I work for crest) but the first post made it sound more like a regulator than a motor. But couldn't tell without looking. Pm me if you need a hand.
Originally Posted by T3K_V35
(Post 5464516)
Thanx trix...apreciate ya
Thats good because i will more then likely need your assistance :) I will send you a pm
