Question for the 6MT's
I've noticed that the throw out bearing seems to make alot of noise when the clutch is not depressed. About a month ago I had a JWT flywheel installed, and it seems that the bearing makes even more noise now. I was thinking of taking the car in to have it inspected, but I'm afraid that they will see the flywheel and tell me I'm on my own for the repair. I know it doesn't cost that much, but then it will go into their system and if I have any tranny trouble, I'll be fighting with them to fix that aswell. I was thinking of removing the flywheel and putting the stock one back in, but then I've already spent the money and may aswell have the bearing replaced then. It's a delima, but the oh well. Any suggestions.
<font color=blue>2003 Caribbean Blue Coupe 6MT Prem, Aero, Nav.</font color=blue>[img]/w3timages/icons/cool.gif[/img] |
Re: Question for the 6MT's
Why didn't you have the throw out bearing replaced when you had the new flywheel installed in the first place?
I noticed the same thing with my car also regarding the throw out bearing. It's starting to make a lot of noise now and it really bothers me. Also in the long run, a bad throw out bearing can sieze and cause major problems to the engine. So pretty much taking it to the dealer for them to repair it is a good preventive measure from major engine damage. Plus it should be still under warrenty.
I would go ahead and have you and a friend swap out the flywheel. Then take it to the dealer for the clutch job. - Don't argue with idiots. They will bring you down to their level and beat you with experience.=P- https://g35driver.com/rides/spec/pix...1066723564.jpg |
yes, my 6MT makes excessive chatter as well. i thought it was normal, but if the dealer will fix it, thad be great. tell us how it goes.
G35S 6MT Technosquare ECU 350Z Springs & Struts 6-wire ground kit |
Your throw out bearing is making noise when clutch is not depressed? Isn't the symptoms of a bad throw out the opposite? The throw out bearing shouldn't be doing anything if the clutch is out, unless it's contacting the pressure plate in some way. Correct me if i'm wrong.
Anyway if it's real bad i agree with the other poster, put it back to stock and bring it in. Hopefully it's not a bad pressure plate. |
I didn't have the bearing replaced when the new flywheel was put because it wasn't that loud before. I had the work done at Oceanside Nissan - They're really cool about aftermarket stuff. I actually ordered the flywheel through them. I would do it myself, but with work I usually don't have the time to do that type of work to the car, I'd rather pay some one to do it. Well I'll try to schedule a day to have the car checked, and I'll let you guys know what happens.
my 6mt makes the same noise. my dealer (idiots) said that it is a normal noise, i am going to keep complaining about it. hopefully the tranny will die and i can get a newer one that shifts a little better, i have difficutly downshifting (which the dealer also says is normal).
2003 G35 Coupe, 6sp, Laser Red, Willow 1992 Cherokee Sport Red (daily driver) |
My TOB makes noise but it's similar to other cars I've owned...maybe a little louder but nothing that I got worried about.
G35s 6MT Garnet Fire, Premium, Aero, Aero Body Kit, Winter Sport |
I only notice it when I first start up the car and it is cold. I hear it when I let the car warm up in neutral with the clutch up, but after it warms up then the noise is gone.
04' G35 Coupe(finally in the garage) 6-sp Diamond Graphite/Willow w/Premium |
Ditto on what Loren just said above here.
Anyone that is thinking about installing lightened flywheels should do their hopework and search on my350Z.com. You will know in advance that they naturally have a "gravel in the tranny sound" at idle to 2K That would make me think it's not such a good mod for me. "All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.” Edmund Burke G35 6mt |
| All times are GMT -4. The time now is 04:46 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
