Synth oil in 5AT trany???
Service manual indicates no other oil to be used other than the Nissan ATF.
I was going to change to a quality synthetic, but it looks like there are issues. ne1 know why? Has there been 5AT problems with other oils? <font color=blue>04 Silverstone G35, 5AT, Prem, Aero ES100 225/45-18 front 245/40-18 rear Borla TD, Z-tube, Eibach, 35%Tints</font color=blue> |
Re: Synth oil in 5AT trany???
I planed on doing it myself but....Dealer says not to...manual say NO.....So I didnt....engine and rear end Yes....tranny...NO
Couldnt afford it when young...gonna play when Im old |
so why cant we use synthetic oil in our 5AT trannies?? anyone else use synthetic in their AT trannies and had problems??
Ya, it seems strange to me, but that's what it says in the manual.
I don't know if it has anything to do with how the trany shifts with synth oil or what??? There must be some reason, but I asked the dealership & got no satisfactory answer. <font color=blue>04 Silverstone G35, 5AT, Prem, Aero ES100 225/45-18 front 245/40-18 rear Borla TD, Z-tube, Eibach, 35%Tints</font color=blue> |
Seems Nissan is pretty anal about what goes in our A/T's. I'd love to change to synthetic too but have been warned by the dealer that all tranny issues are watched very closely for compliance to oil requirements.
If you do change it out and there is a repair issue, you may find that you have no warranty. Sorry for the bad news, I don't like it either. [img]/w3timages/icons/frown.gif[/img] <font color=red>GSM</font color=red> https://g35driver.com/rides/spec/pix...1055534520.jpg<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black> |
interesting I take my car to infiniti all the time and they have always put synthetic in since I took the car their for my first oil change. I havent had a problem at all.
There may be seals in our trannies that are incompatible with synthetic fluids. Use synthetics, and maybe you get tranny fluid leaking all over the ground. Low/No tranny fluid in the tranny is bad...
'03 G35s 5AT, Garnet Fire/Willow Staggered 18" SSR GT1/Bridgestone PP S03 Eibach Springs/Sways, Stillen 2-pc BBK Stillen Intake & SS Cat-Back Dual Exhaust |
damn!! i was planning on putting synthetic oil in too. now i have doubts. this sucks. time to do some major research.
Clarification: The question is about Transmission fluid, not engine oil. It is safe to use synth oil in your engine, but not recommended to use synth tranny fluid in your transamission.
https://g35driver.com/rides/spec/pix...1048800978.jpg <font color=red>chinee</font color=red> 03.5 G35s |
The new Nissan ATF is fully synthetic and of EQUAL quality to any other synthetic. Due to a change to 2 lock up clutches a special slip/lock curve additive is required and the greater durabilty of sythetics to reach 100,000 miles. So far no manufacturer Redline, Mobil 1, or others have come out with an ATF that meet the JATCO stick slip specification.
Just like Toyota has special synthetics for their 5 speeds, JATCO has followed suit to optimize shift feel. The JATCO [Nissan] ATF is made from the same base stock as Mobil 1 Sythetic. In fact almost all but the cheapest generic Dexron ATF are made from sythetic base stock now. If you feel you must use something else[ a Dexron IIIe equivalent] be sure to add Lubeguard Black at about 8 ounces [experiment upward from 5 ounces in tiny increments] to the new ATF it will then be close [approximate] the characteristics of the oem ATF in one parameter. The affects on long term clutch wear are unknown with this combination. Buyer beware and take personal responsibility for your experiments. All failed trannies are tested [back at JATCO Tennessee facility] for oem ATF ---- changes in formulation will be grounds for warranty denial. But that is after the fact after the tranny has been changed.....what they can do at this point is debateable? |
Q45tech
Thanks for the info. I knew there was likely a good reason for the specification, but never had it adequately explained before. I will definitely stick with the Nissan ATF now that I know. Thanks again. <font color=blue>04 Silverstone G35, 5AT, Prem, Aero ES100 225/45-18 front 245/40-18 rear Borla TD, Z-tube, Eibach, 35%Tints</font color=blue> |
