RPM's at 80 MPH
What RPM are you guys at when cruising at 80 mph? I'm trying to see what the actual #'s are for people depending on FD gears.
I have a early 2003 sedan. 3.3 FD open diff. I'm right at 2875 rpms when at 80 MPH. I am 5AT. 3.3 FD Tollboothwilley 2875 5AT Candlestick ~2900 5AT Radioguy21 ~2900 OCG35 ~3000 5AT Blue Dream ~2900 5AT Ttrank ~2600 6MT TwiilightBlue 2850 Antipd32v 3000 5AT X ntrinsik 2900 5AT 3.5 FD Tollboothwilley ~3100 5AT CandlestickPark ~3200 5AT citymunky 3000 6MT thescreensavers 3050 Blue Dream ~3200 5AT AaronHL ~2900 6MT OKStateG35 ~3200 5AT X ntrinsik 3200 5AT NAT@FFTec 3000 6MT alfhasg35 3100 6MT SpeedDream ~2900 6MT 3.7 FD OCG35 - 3250 5AT 3.9 FD 4.08 FD tampagsedan 3450 6MT |
I think my X has 3.5 gears stock, but I'm not 100% sure on that. Anyway, my RPM's are just over 3K at 80MPH. I'll get a closer estimate next time I'm on the highway.
about 2800-2900, stock 3.357 VLSD
edit: running stock 235/45R/18 sized tires |
Recently upgraded to a 3.5 FD w/vLSD (love it!). Will probably eventually go with 3.7 gears.
3.3 FD ~ 2900 3.5 FD ~ 3200 |
for my car:
3.3 at 80mph = 3K rpm (with 235/50/17 - iirc) 3.7 at 80mph = 3250 rpm (with 245/40/19) |
Numbers updated.
OKstateG35 - find out your numbers and post them up please. |
if you want specific relevant data, you should request/require tire size... since they will alter speed if not exact diameter as OEM.
2900
stock vlsd 3.357 245/40/19 all around |
3,000 @ 82mph, 6MT
Originally Posted by AARONHL
(Post 4639594)
3,000 @ 82mph, 6MT
Yes, that should be correct. I only specifically remember the speed at 3k on the dot. Stock tire size.
04 g35x all stock except a ztube and pop-charger 3k right on @ 80mph, I have done extreme amounts of long distance highway driving in the G and I always thought that was a bit high :dunno: btw I have stock rims and stock tire size
I'll have to check. I'm 6MT with 3.3. I think it's in the 2600 range but will check on the way home if traffic is light.
I'm also going to move this over to the drivetrain section. |
2005 G35 Coupe 6MT with 3.5VLSD
80MPH ~ 3000 RPMs 275/35/19 on the rear tires |
2004.5 6MT sedan
2850 @ 80mph running OEM 215/55/17 I'm assuming I have the 3.3 VLSD |
| All times are GMT -4. The time now is 01:11 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
