6MT Clutch Replacement Options
Old Apr 1, 2010 | 09:06 PM
6SP33D's Avatar
Please don't shoot me if I am being redundant. I searched. I couldn't find a solid answer.
2003 G35 C 6MT. 78K miles
The clutch started slipping and I guess it's time to change it. I would like to know what my options are besides the OEM clutch. I drive fairly aggressively, and planning do some occasional track days on it. Also, who are some of the online retailers that I could buy from?
Thanks!
Old Apr 1, 2010 | 09:12 PM
Tollboothwilley's Avatar
you need to try an "advanced search"
and sort by relevance
just search CLUTCH or AFTERMARKET CLUTCH
you'll find like 1000000000 results
Old Apr 1, 2010 | 09:53 PM
HenryLee's Avatar
^ +1
Old Apr 1, 2010 | 10:07 PM
6SP33D's Avatar
Thanks guys. I used the Advanced search. Looks like ACT and JWT are the after-market options. Although going to after-market means I need to change flywheel?
Old Apr 13, 2010 | 01:19 PM
Bauer418's Avatar
IMO you should do the flywheel at the same time. Most likely your OEM flywheel is warping and has heat spots as any flywheel will at 78k. Plus, it doesn't take much more labor to do the flywheel if the clutch is already being done. With that said, I don't know if the factory flywheel can just be resurfaced (because it's a dual mass - correct me if I'm wrong), so you'd be better off swapping it out. I have heard good things about RPS as far as chatter goes, but not sure about performance.
Old Apr 13, 2010 | 01:27 PM
6SP33D's Avatar
Thanks! I got the Exedy OEM + ACT Street combo. It's going to the shop on Thursday. It's been more than a week since I drove my G
Old Apr 13, 2010 | 01:30 PM
Bauer418's Avatar
Both excellent brands. Should be fun to drive when you get it back, but prepare for low RPM chatter (probably not too bad, but noticeable)
Old Apr 20, 2010 | 04:16 PM
6SP33D's Avatar
So I got it installed for a few days now. I notice the chatter very rarely. There is no idle noise, which made me think that I should've gone with a lighter flywheel.
The clutch feel is different. The clutch is more like an on-off switch, rather than a progressive feel. I feel like a n00b again chirping the tires. I don't know if it revs up faster, but it does rev down faster. It feels like I lost some engine braking. The G definitely has a different character to it now, it feels lighter through the turn (loss of engine braking?).. still not sure if I like it.
btw, what's with 750miles break-in period with the clutch?
Old Apr 20, 2010 | 04:29 PM
Alan's Avatar
my jwt combo didnt make any noise when new... before long it sounded like a cement mixer
Old Apr 20, 2010 | 05:25 PM
cdubel01's Avatar
CLUB MODERATOR
^+1...
My JWT Light weight clutch and flywheel sound like a cement mixer when in neutral, but otherwise I like it...
Old Apr 20, 2010 | 09:23 PM
Bauer418's Avatar
You have a brand new clutch disc. Give it a few hundred miles and you will have a more smooth engagement. The break-in period is basically to prevent you from glazing the clutch and essentially have an immediately useless clutch. It's analogous to the engine's 4000 mile break-in period. Just don't slip the clutch or try any hard launches during the suggested break-in. You'll most likely regret it. But again, I can almost guarantee the engagement will become smoother.
Old Apr 20, 2010 | 10:50 PM
Hossmaxima's Avatar
I went with OEM Exedy clutch and a ACT prolite flywheel, love the combo, although with lightened flywheels there is chatter which doesnt bother me
Old Apr 21, 2010 | 11:25 AM
arsine's Avatar
i have an exedy stage1 and act prolite flywheel. its only annoying when i have to wiggle the car around in a tight area. on the open road the clutch and flywheel are great.
tiguy99
Mar 1, 2016 11:42 AM
NemesisGee
Aug 11, 2015 07:10 PM
TurboEE
Jul 31, 2015 10:41 AM
socalg35x
Jul 28, 2015 10:42 AM
