If you guys STOMP on the clutch pedal you'll like our transmission
I've been stomping fast and hard on my clutch pedal when shifting. It has actually improved the smoothness between shifts. Would this be a throw out bearing problem??
I'm replacing the clutch soon, along with a new throw out and input shaft bearing.
Aaron
Aaron
It been my experience that you're simply warming up the clutch disc a bit and removing some of that material that accumulates on the flywheel which tends to cause some grabbiness.
Maybe, but usually when I push it slow, I hear and feel a clunk which seems like the throw out bearing is getting a workout? When I stomp on the clutch, it actually seems like the transmission wants to go into another gear. I feel the shifter slide out of the gear with less effort from my hand.
It's just strange...My clutch isn't slipping regularly, however I'm due for a fluid change and the input shaft bearing is a can of rocks. So I want to replace everything soon.
bTanz
Oct 15, 2015 02:31 PM
