After installation of Transgo engine won't start
Hi guys,
Here is my problem. I installed the Transgo kit last night, and finished up the work this morning by refill the transmission fluid. Now the car won't start at all, no crank no nothing. I can tell the gear indicator is not working, shows nothing but blank. Now I assume the problems could be: 1. there is a sensor somewhere i failed to connect, which is unlikely, i checked every step every cable thats hanging around the transmission. 2. transmission fluid over filled. will this cause the sensor fail to act normally? I can still move the gear stick and the machine reacts accordingly. Only without showing the gear icons. BTW, the brake feels realy hard when stepping on for starting the car or change gear. Any idea? i am so desperate right now. didnt even sleep for almost 24 hours. any help will be appreciated. thans guys. |
sounds like you missed a plug, the ecu looks to the tcm to detect the park/neutral status.
Yup sounds like a fail safe mode, because something is not right.
| All times are GMT -4. The time now is 12:14 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
