Will it bolt right up to a G35 coupe 2005 revup 6 speed or modifications need to be done? The 2015 gear's are 3.69, and that's what i want on my G35... or how about the 2007 g35 sedan diffs or would they fit? If that doesn't fit, what model car with a 3.69 (maybe the complete pumpkin/differential) will bolt up to my 2005 G35 coupe 6 speed with out any modifications or very little modification. Thanks.
What you're showing here is just an open differential, not even an LSD. It will have zero effect on your gearing either. You need the whole pumpkin, or the ring and pinion at a minimum.
As far as bolt-on fitment, you need a 6MT diff from 08-present G37/370Z for the 3.69 gears. 07-08 G35 Sedans also had 3.69 gears on both 6MT and AT models, however the flange that bolts to the drive shaft is different on AT models. There's write-ups on the modification needed. 6MT diff is plug and play.
Alright I found a 2007 G35 sedan manual Differential pumpkin for sale (3.69 gear)... so that's good to go right? Thanks for your help btw.
