throwout bearing/sleeve question.
Old 03-16-2018, 10:55 AM
g35life's Avatar
I just installed my new throwout bearing on the sleeve...
30501 & 30502
https://www.infinitipartsdeal.com/di...5/321_A001.png
the new throwout bearing is loose on the sleeve, i can take it on and off with my hand quite easily...
am i screwed? do i need a new sleeve now?! can i use loctite on the sleeve ?
Old 03-16-2018, 11:39 AM
cleric670's Avatar
BANNED!!!
Received 2,456 Likes on 2,150 Posts
Coupe 6MT Premium RAS
I'm not totally sure what you're saying, you pressed the bearing onto the bearing carrier yes, or did it come assembled already. There is no way the two should be loose since it requires a shop press just to assemble those two pieces.
EDIT: are you saying the bearing carrier is loose on the nose cone of the transmission?
Old 03-16-2018, 01:49 PM
g35life's Avatar
i made a video...
Old 03-16-2018, 02:02 PM
cleric670's Avatar
BANNED!!!
Ok I see what you mean... I've never seen the bearing loose on the carrier sleeve like that before honestly, my gut instinct is they shipped you the WRONG or a DEFECTIVE bearing.
What does the number on the bag it came in say, I think the correct Nissan/Infiniti part number is 3050269F10, is that your existing bearing carrier sleeve?
Old 03-16-2018, 02:23 PM
g35life's Avatar
i got it from Z1 motorsports.... i called them they said it was fine to put it on.
Im not sure what to do at this point, seems sketchy.
Attached Thumbnails throwout bearing/sleeve question.-screen-shot-2018-03-16-2.23.18-pm.png
Old 03-16-2018, 02:42 PM
cleric670's Avatar
BANNED!!!
Something definitely sounds wrong, if you start rotating the bearing ON the carrier sleeve then it's going to create a lot of heat. If it's the same bearing carrier sleeve and you pressed the old one off then I'd say you ended up with a defective bearing. If it's a DIFFERENT carrier sleeve and you never saw a bearing attached to it then I'd say the fault is likely the sleeve. Just to verify the packaging was for an OEM throw out bearing yes and it had the proper ID number I listed earlier, the package was unopened?
Old 03-16-2018, 02:47 PM
cleric670's Avatar
BANNED!!!
Just for the sake of checking, exactly what markings are stamped on the bearing? It's not a Koyo RTC40SA3 is it?
Old 03-16-2018, 05:26 PM
g35life's Avatar
The bearing that I took off it was a g35/350z bearing .it wasn't spinning on the sleeve at all .when I took off the old throwout bearing .
The z1 bearing that's spinning on the sleeve. Its a koyo RCT4000SA. That's the one I got from z1
Old 03-16-2018, 05:37 PM
cleric670's Avatar
BANNED!!!
That's the correct bearing. I guess your bearing carrier sleeve is damaged, it's possible the old bearing was seized and spun on the carrier and wore it down considerably or maybe it was defective in the first place.
I'm surprised Z1 said it's ok to install like that, did you email them the video link so they could looks at it?
Old 03-16-2018, 08:34 PM
g35life's Avatar
The old bearing was on there good . Thanks for your prompt replys . Really appreciate.
rob40wilson03
07-28-2008 07:31 PM
jadenharrow
01-20-2007 02:47 PM
Dr_jitsu
Forced Induction
08-30-2006 02:36 PM
clokwork
06-01-2005 02:55 PM
Quick Reply: throwout bearing/sleeve question.
