Car won't start
Old May 22, 2022 | 11:11 PM
abbymeesha's Avatar
G35s
Car won't start
My car was running this morning it wouldn't start I replaced batteries fob locks and unlocks but car won't start. I have 07 g35s
Old May 23, 2022 | 08:22 AM
telcoman's Avatar
Veteran: Army
Is it possible that you ran out of gas?
Check for spark
Check for pressure from your fuel pump
If you are unable to perform the above perhaps you might be better off having AAA flatbed your vehicle to the nearest Infiniti dealer and pay for a one hour diagnostic check
Good luck
Old May 27, 2022 | 09:09 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
There's a security indicator LED light on the left side of the dash, when you are cranking the engine if it's SOLID RED then the vehicle doesn't recognize your key. Sometimes the BCM just has a heart attack and forgets the key transponder ID code and needs to be reprogrammed.
If that's not it I would add 1 gallon of fresh gas just to rule it out, the gas gauge is notorious for failing and showing 1/2 tank even though it's completely empty.
FRUG35
Aug 9, 2015 07:55 AM
RedG35Az
May 14, 2014 10:03 PM
ModMe
Jan 27, 2007 12:24 PM
pointman1
Dec 9, 2004 01:49 AM
