DIY:*FIX* Coolant Air Bubble [ Heater not working / Temperature jumps / Loud BOOM ]
  #46
Old 11-25-2009, 02:14 PM
Heist.'s Avatar
AARONHL - Seems like an unusual problem. I recommend draining the fluid and starting over. DO the bleeder a couple times. If the problem still persists unless you have deer fur in a radiator hose my last guess would be the heater core. IF so I can only say good luck . Hopefully someone else can chime in with a better explanation to solve your problem . I'm really not positive!
I might send you a pm today about the sedan decals
  #47
Old 11-25-2009, 04:20 PM
AARONHL's Avatar
I'll try draining and starting over. How do I flush the heater core?
  #48
Old 12-21-2010, 09:46 PM
G4orce03's Avatar
AARONHL did u ended up fixing the problem this is currently happending to my car. I tried bleeding Rad system and no help....if u did fix or find the problem, fill me in. Thanks!
  #49
Old 12-22-2010, 11:38 AM
AARONHL's Avatar
Yes, all I had to do was bleed the system. Took a while to do, but now my radiator is leaking. Hahaha
  #50
Old 01-28-2011, 01:42 PM
Townshend's Avatar
wlzxTy
  #51
Old 01-28-2011, 01:43 PM
Townshend's Avatar
Smile
ZxwlTY
  #52
Old 02-05-2011, 01:11 AM
AARONHL's Avatar
Replaced my radiator and the heat is ICE cold. Not sure what to do, I bled it a couple times. Maybe I will let it sit and try again..
  #53
Old 02-05-2011, 01:21 AM
AARONHL's Avatar
Heat was fine before the radiator swap.
  #54
Old 11-09-2011, 02:24 AM
RADRaze2KX's Avatar
anybody have a working mirror to the original post?
  #55
Old 05-14-2012, 04:37 PM
teahead's Avatar
Anyone have a picture of this air bleed/relief valve in the engine compartment? I can't seem to locate it.
  #56
Old 05-14-2012, 04:42 PM
AARONHL's Avatar
You don't need a picture, look between the battery, engine, and firewall. There are some silver pipes and on one is the bleeder, it's a black plastic screw.
  #57
Old 05-14-2012, 04:43 PM
bythabay's Avatar
check 2:59
coolant replacement video
  #58
Old 01-23-2013, 09:03 PM
Darkstar752's Avatar
AARONHL, did you ever fix the problem after the new radiator? I'm having the same problem now. It doesn't really bother me that much since the car isn't overheating, but it's definitely annoying.
This happened after I drained/refilled the coolant. Doesn't seem like it's circulating to some areas. My fans kick on just fine, and I can spit coolant out the cap and bleeder valve just fine but can't get anymore bubbles to come out. I did get a good amount of them out, seems like there's one giant one stopping me. Lower radiator hose remains cold even after a 20 min drive. FWIW, I poured in the new coolant slow as hell, like 4-5 minutes to put a gallon in there.
  #59
Old 01-23-2013, 10:29 PM
bigc's Avatar
Wings Nation
I recommend you use the Lisle spill free funnel to bleed the coolant system if you haven't tried it already.
  #60
Old 01-25-2013, 08:57 PM
AARONHL's Avatar
After I changed my radiator, I let the car sit overnight and in the morning the lines were fill and was able to bleed it
Quick Reply: DIY:*FIX* Coolant Air Bubble [ Heater not working / Temperature jumps / Loud BOOM ]
