DIY: cam position sensors
Old 06-17-2014, 11:06 PM
Urbanengineer's Avatar
Received 1,018 Likes on 936 Posts
"Sorry, I was just trying to impress you"
  #47
Old 06-17-2014, 11:11 PM
Lartytiejdke3's Avatar
I impressed all the bishes with my SOHC d17 daily driver
  #48
Old 06-17-2014, 11:47 PM
ScraggleRock's Avatar
Am I am the only one on this site who's G is his first import?
'Murica!!
  #49
Old 09-09-2014, 02:13 PM
Uprevtuning's Avatar
Question on Cam position sensors.
Originally Posted by snakes1021
haven't seen one of these but seen a few questions on this. so ill try to explain it this is my 1st DIY thread so bear with me.
they could have make the sensors the same and saved money but they didn't the only difference is the angle of the plug. and you could swap them is the grooves on the connectors weren't reversed
TOOLS: 10mm socket, 10mm box end wrench, flat head screw driver.
1. disconnect batt.
2. get to work remove intake and (engine cover 2 bolts and 2 nuts)
3. remove upper plenum
4. remove lower plenum
5. move wire bundle to access bank 1 sensor
6. remove 1 10 mm bolt and pull the sensor out
7. replace with new sensor
8. remove breather hose from valve cover (forgot to circle that one but youll see it. if you dont get some glasses)
9. remove 1 10 mm bolt and pull out bank 2 sensor
10 . replace sentor
11. re-assemly, johnny 5
12. reconnect batt.
13. turn her on.
PIC 1: Upper plenum (remove bolts(alot), nuts and 3 or 4 hoses,i think there is one one the bottom of the TB, circled)
PIC 2: lower plenum (remove 6 bolts in center, 2 nuts and 1 hose, circled)
PIC 3: sensor positions (left side = passenger)
PIC 4: sensor before removal(1 10mm bolt holds that sucker in and an "O" ring gotta wiggle it to get it out)
PIC 5: sensor after removal
I got my sensors mixed up. Could someone show me a pic with the sensors in so I know which side the one with the elbow goes?
  #50
Old 09-09-2014, 09:49 PM
Bank one is straight. Bank 2 is bent.
  #51
Old 09-09-2014, 09:54 PM
Bank 2 on right standing outside of car looking at engine bay from the Infiniti logo.
  #52
Old 09-14-2016, 07:08 PM
arianeb24's Avatar
Replaced both camshaft position sensors but still show codes
My service engine light went off after replacing camshaft position sensors but slip and other lights still on...is there a way to reset them or is there still a problem i haven't figured out yet? Help please!!
  #53
Old 09-15-2016, 09:12 AM
daviston's Avatar
Have you tried resetting the Service engine lights? Usually when you reset all of them after you do the replacement of the sensor they will all go away. That procedure is all over this site. Just search for it.
  #54
Old 09-15-2016, 07:01 PM
arianeb24's Avatar
Thank you for your response. Yes i reset the ECU but lights are still on its driving me crazy.
  #55
Old 09-16-2016, 01:28 PM
Pit-racer's Avatar
P0011 and P0021 fault codes mean we need to replace?
  #56
Old 11-07-2018, 12:31 PM
liferiders's Avatar
2004 Infiniti G35
Newbee here. Can you help me identify which sensor is this?
It seems to me that this sensor (looks like a sensor) is broken. I am not sure which is this part. Can you help me identify what this is? What you see is on the passenger side of the car. Close to the radiator. You can see the radiator hose going very close to this part. It is a green colored switch. Not sure what is is connected to? It seems to me that is broken and must be replaced. but I am not sure,what it is.
Thank you for all your help.
  #57
Old 11-07-2018, 02:38 PM
Not seeing a photo?
  #58
Old 02-18-2021, 10:16 AM
Kevin Strasser's Avatar
g35
Same problem I have you find problem
Originally Posted by G35sil
Ok so my problem is that i would get 4 codes all the time and it always comes back to haunt me. Car would not go over 2300rpm when all lights are on. I unplugged the driver side cam sensor and car can reach higher rpm and drives fine.
2003 g35 coupe 6speed manual 93k miles with a 84k miles engine swapped. Motor was never opened up before as i can still see the oem gasket makers squished in place still.
SES light on
VDC light on
SLIP light on
Error code:
P0328(knock sensor high input)
P0011(variable valve timing over advance bank 1?)
P0021(variable valve timing over advance bank 2?)
P0345(camshaft position sensor "A" bank 2 circuit)
I replaced the knock sensor with a autozone one, still same codes and problem driving
I replaced the driver side cam sensor with a nissan one and problem still persists.
One thing i did find out weird, bought a oreilly cam sensor for driver side, car just cranks and not firing up. Returned it and got another one, same thing. So i went to autozone and bought one, still same results. Finally i got sick of it and went to nissan and bought one. Fires my car right up and runs. But problem jerking and not going over 2300 rpm still there.
i can unplug the driver side cam sensor and the car would actually run normally but with all the warning lights on. Just takes 3-4 seconds to start up, car never shut offed on me either, runs with the cam sensor not plugged in and still runs after plugged in with all warning lights on. Last thing i want to hear is timing jumped. And the engine sounds quiet and normal. Dont hear any chain slapping or tensioner ticking
If anyone can help i would really appreciate it.
Message me or post on here thanks
Did you find Solution to a problem
Scorpi0
04-04-2019 06:34 AM
Mr. Uy
41
02-03-2016 06:58 PM
1YoungOwner
Drivetrain
21
03-31-2014 11:16 AM
jsmith29
04-17-2012 10:58 AM
MIA Philly
04-13-2011 09:14 PM
Quick Reply: DIY: cam position sensors
