G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Engine, Drivetrain & Forced-Induction (https://g35driver.com/forums/engine-drivetrain-forced-induction-19/)
-   -   G Won't Start - - Please Help (https://g35driver.com/forums/engine-drivetrain-forced-induction/228293-g-wont-start-please-help.html)
ColtonChristens Jun 19, 2008 05:15 PM
I have a 2006 G35 Coupe. It was a theft recovery car that i built for my wife...aparantly who ever stole the car took the small fuse block cover off of the cowl leaving the fuse block exposed. I realized it was missing a few months ago when i was washing the car and the headlights began to strobe on their own. I meant to find a new one and get it put on right away, but it hadn't really caused a problem in several months so i kind of forgot about it.
I took the car for another wash (BTW there had been several washes between the one where i realized the cover was missing and this one with no problem) drove the car home with no problems what-so-ever, and the next morning i came out and it will only crank, try to fire, and die. I let it sit for a week now to try and make sure it was perfectly dry and still nothing.
I am getting a high pitched ringing noise from a module on the intake. I would imagine that this is probably what is preventing the car from starting. I'm not even sure what to call it. It has cooling fins on it and sits right at the front of the intake manifold.
Any help would be greatly appreciated....This thing has me stressed out and missing my car very much!
EricIsKlumzyee Jun 19, 2008 05:34 PM
throttle body? O.o
are you getting a code/engine light? check the fuses? check connection to the fuses? is there gas in the car? does it crank now? battery?
ColtonChristens Jun 19, 2008 05:37 PM
No codes. I have checked fuses and the connectionto them. There is gas. It does crank but i have to use the starter box because it seams that the hi pitch noise is draining the battery.
EricIsKlumzyee Jun 19, 2008 06:14 PM
high pitch noise there after you have the key off?
take a picture of what you think is making the noise and post up
- Eric
ColtonChristens Jun 19, 2008 06:26 PM
Ya it is there after the key is off...thats a good idea. I'll try and get a pic tonight.
xnyc Jun 19, 2008 07:03 PM
try disconnecting the 2 tb connectors and reconnecting it.
ColtonChristens Jun 20, 2008 11:52 AM
Here is what is producing the high pitched noise.
http://www.corvetterecycling.com/colton/img053.jpg
ColtonChristens Jun 20, 2008 12:29 PM
I'll give it a shot tonight.
superchargedg Jun 20, 2008 07:10 PM
That is the electronic drive by wire with tps sensor built in that is a part of the throttle body assembly.
ColtonChristens Jun 20, 2008 07:16 PM
And if it were cooked i would imagine that it would definatly keep the car from starting right? Any idea where i might find a used one?
EricIsKlumzyee Jun 20, 2008 07:39 PM
^ 350z forums there are more guys there with a drive-by-wire converson then us
superchargedg Jun 21, 2008 06:05 PM
Just go to the infiniti dealer and buy one.Mine cost $149 with gasket and it is easy to replace.
ColtonChristens Jun 23, 2008 11:08 AM
When yours went out did it prevent the car from starting?
superchargedg Jun 23, 2008 07:07 PM
No mine would only rev to 1100 rpm's.
© 2026 MH Sub I, LLC dba Internet Brands
