Official: Car won't start
Old Nov 29, 2008 | 09:51 PM
App6MT's Avatar
Littering and...
Angry Official: Car won't start
So I pulled my engine to take off the turbos and I'm having trouble getting it to start when it's back to stock.
Current state:
MAF is hanging loose, no airbox, grounded to engine via screw
Plenum is split apart, all vacuum hoses are attached
I checked...
voltage to coil packs
voltage to injectors
power to ECM
power to IPDM
pulled the gas line off the regulator and primed the pump, pissed out gas - poured gas down the intake runners as well
flywheel positioning sensor
The car turns over but won't fully crank.
I think it's a grounding issue, but I've checked all the grounds I can think of. Maybe need to recheck them.
Any ideas?
Old Nov 30, 2008 | 06:49 AM
djCypher's Avatar
Originally Posted by HomieG35
Current state:
Maybe I'm dumb... but you're trying to start it like this?
no type of ecu mod or bigger injecters for the old turbo setup either?
Old Nov 30, 2008 | 07:02 AM
KSWAY's Avatar
Plenum split apart?
Old Nov 30, 2008 | 07:43 AM
App6MT's Avatar
Littering and...
The car won't start with the plenum together either. I took it apart to check voltages on the injectors and coil packs.
The car should start, it will just have a rough idle and die.
Old Nov 30, 2008 | 07:44 AM
App6MT's Avatar
Littering and...
ECU is back to stock. Checked the power to the ECM and to the IPDM. Stock injectors as well.
Old Nov 30, 2008 | 07:53 AM
App6MT's Avatar
Littering and...
I just remembered I have one step colder NGK plugs. Again, I would think it would start, but trying to think of everything.
Old Nov 30, 2008 | 07:55 AM
KSWAY's Avatar
when ever something like this happens to me. It's always something so retarded that i over looked. Like forgeting plug a sensor in or plugging it in all the way..
Old Nov 30, 2008 | 09:02 AM
App6MT's Avatar
Littering and...
Yeah. I am planning on going down (once the rain stops) and undoing all the sensors and plugging them back in.
I really think you're right with it being something dumb, but it's pissing me off
Old Nov 30, 2008 | 02:33 PM
djCypher's Avatar
sounds more like a grounding problem
Old Nov 30, 2008 | 06:39 PM
str8dum1's Avatar
if you maf is not plugged in and attached to the intake manifold, it will not run.
Old Dec 1, 2008 | 07:56 AM
App6MT's Avatar
Littering and...
How about: the MAF is plugged in but I just have it physically in the intake - it's just dangling in the air.
Old Dec 1, 2008 | 08:30 AM
GreenGoblin's Avatar
The goblin resurrection
It would start with out the maf sensor just would run very bad. I would go back check all the connections and see if one is half way connected, then check the fuses and see if something popped.
It is trying to turn over but not catching right?
Old Dec 1, 2008 | 10:13 AM
App6MT's Avatar
Littering and...
Yeah it's turning at the full 200 rpms from the starter, but doesn't seem to be getting any spark. I did what the service manual said to do: tie a piece of string to the ignition coil with the spark plug and hang it 13-17mm above the engine block. If it creates a spark, it's fine. Well it doesn't spark.
I checked the dedicated 12V, it's reading the same as the battery. I checked the ignition pulse, it's reading 0.32V which its suppose to be 0.1-0.4V, so that's good. But it's not firing.
Old Dec 1, 2008 | 10:55 AM
dieselaznrock's Avatar
I still don't understand if your plenum is split apart or not, but if its wide open it might not start and your MAF hanging loose and all may prevent it from starting too, when my MAF was out it would not start up. But thats just my experience.
