coupe Q's
is there anything else that has to be maintaned on the g coupe besides brake pads and oil changes ? like any technical things?
Re: coupe Q's
I think there is a whole list of things in the owners manual, but I'm not sure.
One day I'll look at it. 2004 G35C 6MT Black. Killer. |
Re: coupe Q's
Just follow the schedule in the owners manual for routine maintainance. If you are really picky (like me) you'll change all of your fluids out early...
Oil at ~1200 miles (just before break in is over) Transmission ~7000 miles Differential ~7000 miles This allows the burrs or shavings due to pitch circles of gears not being exactly aligned, or parts not being properly scaled or de-burred to be flushed out of your system early on. The dealership can do a "flush", much different from a "drain" on both of these items. By 7000 miles, any lose pieces of metal will have worn off and should be able to be flushed out of your system rather easily. That's the only extra thing I would recommend. Then again, if you're leasing your car, or do not plan on keeping it past the 5 year 60,000 mile warranty I would not spend the extra money on these 2 things. <font color=blue>The above statements are only my take on the issue. If you disagree with anything I typed then you are 100% right!</font color=blue> |
| All times are GMT -4. The time now is 05:52 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
