UT's CF Intake INSTALL
Just wondering where people found the instructions to do this. Search of this site and others did not yield any good results. I am guessing it is as simple as the JWT PopCharger (which I found install directions for, thanx), but might be a bit different?
Any help/references would be welcomed as I just received this setup yesterday, and would LOVE to install it tomorrow! ...Maybe I will even post pics of MY install. :) |
Re: UT's CF Intake INSTALL
It's should be a fairly simple DIY install as with most intakes.
Perhaps you can ask the moderator G35Lin, I know he has one installed. Good Luck. |
i'll create a DIY this weekend. SOMEONE is ASKING ME TO DO IT!! You know who you are1 :P
Ed 2003 Transport V35SKYLINE. Team Transport! www.teamtransport.org |
I installed this intake over the weekend.
I could not figure out how to use the bracket that the kit came with. So I ended up going to Home Depot and buying a piece of steel to use as a bracket. I drilled a hole on both ends. One end I mounted to the frame using an existing bolt. The other, I ziptied to the intake filter box. I'll try to take a picture of my setup and post it. |
| All times are GMT -4. The time now is 05:31 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
