G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Engine, Drivetrain & Forced-Induction (https://g35driver.com/forums/engine-drivetrain-forced-induction-19/)
-   -   Help! What's this bolt hole near Plug #6? (https://g35driver.com/forums/engine-drivetrain-forced-induction/431820-help-whats-bolt-hole-near-plug-6-a.html)
gstuart Sep 3, 2013 06:02 AM
Am I missing something? This is a bolt hole just below plug #6 (driver side plug / closes to firewall).
http://i41.tinypic.com/wi0s4k.jpg
Should nothing be bolted to that?
HotRodG35 Sep 3, 2013 07:04 AM
Its used for coil wire harness bracket mount which may have been removed.
gstuart Sep 3, 2013 07:14 AM
Ok, I may have installed the coil upside down. The letter f on the coil should be facing right side up like the rest of the coils right?
HotRodG35 Sep 3, 2013 07:43 AM
#6 coil pack is reversed from the other 5 coil packs. Orientation of the "F" on coil pack is irrelevant, whats important is its seated all the way on plug and tightened.
#4/#6 are common problem reversing harness plugs because of orientation.
gstuart Sep 3, 2013 07:56 AM
Yeah, I just saw some pics and the #6 is upside down.
The missing bolt is weird since I never touch it before until today. Unless the dealership removed it.
I forgot to plug in the damn intake harness and turned on the car. Now the check engine light is on.
So it's either that or the #6 plug isn't plugged in all the way.
© 2026 MH Sub I, LLC dba Internet Brands
