Vdc/off, SLIP, AND CHECK ENGINE LIGHTS ON
2005 Infiniti g35 sedan.
Hi, i I was wondering with all these lights on. Would I still be able to drive it, until i get it I get it fixed? |
Pull the codes. There is no way to advise you at least semi-accurately otherwise. If you don't have a code reader, get one, honestly Nissan/Infiniti should come with one in the glove box standard. Pull the code(s), plug them into the search function and you'll have a lot of answers.
This^^ and also check your brake fluid. Sometimes low levels will trigger these lights. The most common cause for the three to come on at the same time is a bad camshaft sensor. My guess is you'll pull an P0340 or 0345 DTC which would confirm my suspicions. Both are a pretty easy fix if you're handy with a wrench, just buy OEM sensors if you need to replace one or both. Our cars don't always play nice with aftermarket ones.
2004 Infiniti G35 SDN. VDC Off, Service Engine Soon and Slip something. Car lost power and bucked. Has been getting bad gas mileage also.
Pull the codes! Likely a cam or crank position sensor. But without the engine code you won't know for sure, or which one.
Same Issue
I had the same issue and I put some more brake fluid and lights went away. Something trigger them light. Also pull codes just in case.
