2005 G35 crank no start
I did a auto to manual conversion on my 2005 g35 sedan. Everything turns on perfect and cranks fine but won’t start. There’s no gear on the selector and “A/T CHECK, SLIP VDC off” are on. Any suggestions on what to do? |
Ok just to verify, you did all the necessary modifications rewring the harness and IPDM, and you reprogrammed the ECM correct?
There isn't a NATS interlock preventing fuel or spark yes? You have verified fuel pressure and verified spark yes? If it's still not starting I would suspect a failed crank or cam sensor. This motor was working before the swap without any problems yes? |
