Car stalls under heavy breakin
I recently installed a oil catch can, IDK if that is involved or not so I thought I would include it. I was driving the other day and my car shut off (stalled) when I was on the highway going about 60 in 5th I put the clutch in b/c there was a traffic light and applied medium pressure to the breaks and the car just died, I tried the idle relearn and ECU reset neither worked, thankfully the car started right back up. Any suggestions on what it could be?
I'm thinking that you were unplugging big vacuum lines and need to check to make sure everything is on tight. I doubt it has anything to do with an inexpensive CC but you should make sure you didn't miss anything that needed to be plugged.
Slamming the brakes takes a lot of vacuum power and if you have a big enough leak the rpm drop can stall the motor.
Just to verify it's not some kind of vented catch can right
You should also check the lines once the engine is good and hot after a freeway drive to make sure they aren't getting soft and squishy which causes them to collapse. Doesn't cause stalling but still something to verify, if you used high pressure fuel injection hose then you're fine.
EnviedG35
V36 General Tech Questions
Feb 17, 2009 01:41 PM
