G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Engine, Drivetrain & Forced-Induction (https://g35driver.com/forums/engine-drivetrain-forced-induction-19/)
-   -   G35 Warrantee issues - What's broke? (https://g35driver.com/forums/engine-drivetrain-forced-induction/52305-g35-warrantee-issues-whats-broke.html)
WI_Rick Apr 27, 2005 12:23 PM
What issues have you had to use your warrantee to resolve?
FloridaG35 Apr 27, 2005 04:59 PM
The only problem I have had with my G35 Coupe is the disc changer. My car won't even play CDs now. It goes into Orlando Infiniti this Friday, and I don't get it back for 17 days!! SUCKS! They've also said this is something common that is happening so if you have any issues with your disc changer they will replace it for you.
WI_Rick Apr 27, 2005 05:01 PM
17 days .... do get a loaner to beat on? Seems like a ridiculous period of time. How long is an oil change?
BlackObsidianX Apr 27, 2005 05:44 PM
only had a few minor issues with the car so far.
at 24k, the warranty has replaced the fuel damper, front brake pads and rotors.
next week, they will look into the creak noise coming form the front suspension when going over speed bump at low speed.
skeleton_cru Apr 27, 2005 10:55 PM
In no particular order...
CD changer replaced
Rattle in passenger door fixed
Rattle in driver's B-pillar fixed
Bad cat replaced
Entire engine replaced
Keep in mind this is an '03 sedan.
WI_Rick Apr 28, 2005 09:08 AM
Why did the engine need to be replaced?
ChicagoX Apr 28, 2005 09:25 AM
Bose HU-on third unit.
Steering wheel tilt- fixed twice for not keeping wheel in position, allowing it to drop in my lap.
Other than that, a flawless ride.
silver04 Apr 28, 2005 01:02 PM
CD changer replaced
Bad cat replaced
:confused:
Entire engine replaced? You have the details on that one?
I tried searching for it under your name but couldn't find the thread.
Texasscout Apr 28, 2005 03:44 PM
Excelent service
So far:
Drivers door speaker (didn't fix the problem of a poping noise)
Back drivers side door weather stripping (attempt at wind noise)
Soon to be done:
Back drivers side door quarter window welt (wind noise)
Back lower leather seat cover (ONE stitch came loose!)
Gave me a loner for 4 hrs
I have NO problem with Gunn Infiniti in San Antonio so far :D
skeleton_cru Apr 28, 2005 05:54 PM
Originally Posted by silver04
:confused:
Basically it was from excessive oil consumption. Here is the thread:
https://g35driver.com/forums/g35-sedan-v35-2003-06/32451-help-engine-failure.html
SoCalTed Apr 28, 2005 06:30 PM
* Brakes @ 15k
* Moon Roof came off the track
* Trunk lid not aligned
* Excessive squeaking in the A & B pillars
* regulator in passenger came loose
FloridaG35 Apr 30, 2005 04:12 PM
Note to self: Never listen to the woman at the desk that directs phone calls. In fact, the service guy cracked up when I asked him about the time line to fix this. Dropped the car off Thursday, should be getting it back on Monday.
Also, got an '05 sedan to beat on. The sedans are real nice too.
SKg35 Apr 30, 2005 10:48 PM
1. brakes replaced under warranty..i didnt even ask for this. they just did it.
2. rear left led brake light assembly....not all lights were lighting up.
3. sunroof squeak
4. drivers seat squeaking and moving a bit
this all in the first 3 months, i bought the car used, but the guys at my infiniti dealership are excellent and it never bothered me the problems, they were fixed fast and efficiently
skeleton_cru Apr 30, 2005 11:39 PM
I forgot about the brakes...
CD changer replaced
Bad cat replaced
Entire engine replaced @ 29k
Brakes replaced @ 28k
jaspergtr May 2, 2005 10:37 AM
do you have an aftermarket sway bar?
if not, you may just want to check the grease in the front sway bushings. obviously, if it is stock, and you don't feel like wasting an hour, turn it in.
just trying to help.
© 2026 MH Sub I, LLC dba Internet Brands
