Engine Cover
Old Jul 12, 2003 | 02:22 PM
Rumble's Avatar
Engine Cover
Does anyone know if the coupe engine cover will fit the sedan and vise versa? I was thinking of spray painting my engine cover, but I may just save some time and see how much they charge for the coupe cover. Thanks in advance.
It's still a G thang!!
Old Jul 12, 2003 | 05:27 PM
Msedanman's Avatar
O.F. Administrator
Re: Engine Cover
Hey Rumble, I'm gonna guess at this and say they have diff mounting holes. My digicam is at Mom's today, so I just measured the bolts centers (front 2 and rear 2) Fronts from center to center are 11.75". Rears center to center are 7".
So get off your butt and get your tape out and go measure it.LOL J/K bro.
You could wait till next meet, or go flag down a Coupe. Best I could do for y'all this time dude.
<font color=red>GSM</font color=red>
Old Jul 12, 2003 | 07:19 PM
DaveO's Avatar
Re: Engine Cover
I'm betting the Coupe, Sedan and 350Z engines are the same... at least externally. Therefore, the engine covers ("ornaments") should be fully interchangable.
I measured the mounting holes on my sedan's plenum/intake manifold ("collector") and they match the posted measurements exactly.
While on the subject of engine covers, I've conducted a very unscientific experiment over the last two weeks.
The results are not suprising. The the plenum runs hotter and retains more heat with the G35's full engine cover in place than when the plenum is uncovered.
My new 350Z "ornament" should be here early next week. And even if my conclusion is wrong, I still prefer the looks of the shorter 350Z cover.
Old Jul 12, 2003 | 07:33 PM
Rumble's Avatar
Re: Engine Cover
Cool, thanks guys!!
GSM > You da man homie!! [img]/w3timages/icons/smile.gif[/img]
DaveO > Do you have any pictures of the 350Z engine cover? Also, lemme know how it goes with the fitting.
Old Jul 13, 2003 | 10:07 AM
RamboRami's Avatar
G35driver.com Moderator
Re: Engine Cover
here you go rumble
G35c 6MT DG/Willow/Grounding Kit
Old Jul 14, 2003 | 09:24 PM
Scoop's Avatar
Re: Engine Cover
Do you think our G35 engines would run cooler with the Nissan half engine cover???
Scoop
Old Jul 15, 2003 | 12:49 PM
RamboRami's Avatar
Re: Engine Cover
maybe if you remove the hood lining insulation as well, it may run a little cooler.
Old Jul 15, 2003 | 02:17 PM
DaveO's Avatar
Re: Engine Cover
Most like removing the underhood insulation would help dissipate engine heat. However the increased noise and elevated hood temperatures wouldn't be good... especially at idle.
I believe under-hood temperatures are much lower at speed and an exposed intake plenum will help reduce the temperature of the air delivered to the engine.
Could be wrong, but I'm willing to give it a try.
Once again, Jayson at Nissan Wholesale Parts made me a deal I couldn't refuse. The big brown truck is scheduled to deliver my 350Z Engine Ornament this afternoon.
Old Jul 15, 2003 | 10:59 PM
DaveO's Avatar
Re: Engine Cover
Installed my new 350Z Engine Ornament this evening. Bolt holes are no problem.
Because I have a Sedan with a engine driven radiator fan, I had to trim about 2" off the front of the cover. Sedans with electric fans shouldn't need triming. The aux air inlet duct clearance is real close, but it does fit. And it doesn't look half bad if I do say so myself.
Old Jul 16, 2003 | 02:49 AM
Rumble's Avatar
Re: Engine Cover
DaveO > Post some pix please! [img]/w3timages/icons/smile.gif[/img]
Old Jul 16, 2003 | 04:47 AM
G35Lin's Avatar
Multi-Spoked Mod
Re: Engine Cover
pics plz! thanks
Old Jul 16, 2003 | 08:19 AM
chinee's Avatar
Re: Engine Cover
Easy mod with no pics??? That's a big no-no.
<font color=red>chinee</font color=red>
2003.5 G35s
Old Jul 16, 2003 | 09:38 AM
DaveO's Avatar
Re: Engine Cover
I've tried to post pictues in the past without success.
If there's no picture with this post, can someone talk me through how to do it?
Didn't work... Help!
<P ID="edit"><FONT class="small"><EM>Edited by DaveO on 07/16/03 06:41 AM.</EM></FONT></P>
Old Jul 16, 2003 | 11:44 AM
RamboRami's Avatar
Re: Engine Cover
pic has to be less than 100K in size, click on the FAQ/DIY forum for the HOW TO
Old Jul 16, 2003 | 05:30 PM
DaveO's Avatar
Re: Engine Cover
G35 Sedan Engine Ornament Picture
