idle issues
Oh crap. Your post just made me remember...
There was a hose connected to the upper end of the stock G35 intuke tubing, approx. 1 inch in diameter. I forgot to reconnect!
But I dont remember seeing anywhere to plug it to the ztube???
What is this hose? And could I have caused any permanent damage driving for 40 miles or so with it open to the atmosphere?
That would be the emissions tube. On a "Z" tube, the said is located underneath. It's between the flex joint and Throttle body of the tube. Hopefully the clamp is still attached. You should be fine. At this point, a simple ECU reset via the pedal method would not hurt. While your at it, be sure to recheck the Throttle Body clamp, as well. Good luck!
esotericrider
02-14-2022 07:19 AM
Silver tiburon
09-04-2015 07:17 PM
